Misfire Issues? Please Help.
Old Dec 31, 2012 | 12:24 AM
CodyDykstra's Avatar
CodyDykstra
Hi all. I did a search and couldn't find much that really helped me so I figure it's time to ask. I replaced the spark plugs on the truck tonight and when I fired it up, the engine was shaking like no other. It's never done that before. I took it for a test drive, and the truck is missing like crazy. I have no idea what the issue is, and need the truck by tomorrow.. If anyone has any ideas, they're greatly appreciated.
I tried posting the truck info by my name but I'm new to the site and I'm not sure if it worked. If not:
1996 F150
4.9 300 Inline Six
5 Speed Manual Trans
2WD
Thanks!
Old Dec 31, 2012 | 12:45 AM
892504x4's Avatar
892504x4
Check your wires , I have not got mine back on right (loose) looked good
Old Dec 31, 2012 | 02:12 AM
CodyDykstra
We checked that first, all the wires are connected good, which is why we are so confused
Old Dec 31, 2012 | 02:33 AM
timbersteel's Avatar
timbersteel
Sounds like wires are connected wrong. I take your word that you checked, but be sure that everything from the distributor is correctly wired. I did the same thing years ago and could not figure it out. After checking and checking, it was misrouted wires. Could also be loose cap and rotor. Just a couple of thoughts.
Old Dec 31, 2012 | 10:10 AM
OldGrayFord's Avatar
OldGrayFord
Depending on how old and what kind of condition the plug wires are in they sometimes get damaged when removing them. If they are good connections and routed correctly it may be worth checking spark individually
Old Dec 31, 2012 | 10:26 AM
bashby's Avatar
bashby
Re-check the firing order
Ddaybc
Jul 10, 2014 11:00 PM
turboguy
May 10, 2005 09:14 PM
modru2004
Oct 4, 2004 08:48 PM
RangerWoman
Sep 2, 2003 09:52 AM
lanero
Apr 14, 2001 10:00 PM
