missing?
Old Oct 1, 2004 | 08:35 PM
modru2004's Avatar
modru2004
missing?
can anyone tell me what the symptoms of a missing engine are? when i floor my truck it revs then its like the engine cuts out for a second then resumes reving rince and repeat. during the cut out or miss i guess the truck shakes pretty violently. at least its very very noticable. i tried my grandads 91 f150 5.8 like mine and reved his and his just revs nice and smooth. nothing like what mine does. is my truck missing on a cylinder?
Old Oct 2, 2004 | 01:49 AM
andym's Avatar
andym
Could be a couple things. First thing I would do is a tune-up, including wires, dist. cap, rotor, spark plugs, filters, and PCV valve.
Old Oct 2, 2004 | 03:09 PM
modru2004's Avatar
modru2004
just had sparkplugs replaced. might need to luck into getting the wires etc done.
Old Oct 3, 2004 | 08:04 PM
Fordfanz's Avatar
Fordfanz
might look in to making sure all the wires are conected right ??
Old Oct 4, 2004 | 07:10 AM
guzzler96's Avatar
guzzler96
Lightbulb
If wires are connected properly. Inspect the boots on the sparkplug end of the wires. I had some that had gotten rather gooey. I would do what andym suggested at the least. Mine ran about 200 percent better just by doing these things.
Old Oct 4, 2004 | 08:17 PM
modru2004's Avatar
modru2004
it was doing it before the replacment of the plugs though.
Old Oct 4, 2004 | 08:34 PM
bossind's Avatar
bossind
Ussally when you have a missing engine the front of the truck sits higher
Old Oct 4, 2004 | 08:39 PM
guzzler96's Avatar
guzzler96
Question
So if you rake the front end the miss will go away.
SERIOUSLY THOUGH, When you had the plugs replaced were all the other things andym suggested done also. Wires,rotor,distributor cap,etc.
Old Oct 4, 2004 | 08:48 PM
Gary B's Avatar
Gary B
do i understand you right? does it quit like you shut the engine off and then back on? if so the fuel filter is probally plugged up
hartford59
Apr 11, 2012 07:52 PM
tractors55033
1983 - 2012 Ranger & B-Series
Oct 13, 2009 05:57 PM
sawz5
Feb 7, 2009 11:11 AM
blue66tang95f150
Jan 13, 2009 09:08 PM
jdschall
Jun 30, 2005 10:31 PM
