Random electrical connectors
Old Dec 30, 2012 | 03:54 PM
Masteratarms93's Avatar
Masteratarms93
Digging around in the engine ay of my 76 today I found some disconnected harnesses and a grounding strap.
Can anyone identify them for me?
Old Dec 30, 2012 | 03:59 PM
HIO Silver's Avatar
HIO Silver
The ground strap attaches to the underside of the hood. It is there to dissipate static electricity and to also ground the hood to act as a ground plane for antenna reception. There should be a corresponding hole drilled into one of the hood's ribs that is missing a screw.
Identify 'em yourself! Some of that appears for be for ignition... but here, you can trace the wire colors and teach yourself about your truck.:
<A HREF=http://i55.tinypic.com/21jw50l.jpg>74-78 Wiring Diagram Pt1</A>
<A HREF=http://i52.tinypic.com/35luc8n.jpg>74-78 Wiring Diagram Pt2</A>
Old Dec 30, 2012 | 04:20 PM
Masteratarms93
Sweet, thanks for the info!
Old Dec 31, 2012 | 12:25 PM
Masteratarms93
So far I have the green one as a connector for the EGR system.
The one harness is for the blower and heater.
The other one I haven't quite identified yet.
Old Dec 31, 2012 | 01:09 PM
HIO Silver's Avatar
HIO Silver
Good job thus far....
Which one has ya flummoxed? Post up the wire colors - main color and the trace color. For example, orange with a yellow trace would be "O/Y" or "O/y"
Old Dec 31, 2012 | 01:13 PM
fmc400's Avatar
fmc400
MSEE
The connectors in your last picture appear to be for the ignition module. A three-terminal connector instead of a two-terminal connector for module power would point to a Duraspark I module instead of Duraspark II; I'm not sure which would be expected for a '76.
Old Dec 31, 2012 | 02:02 PM
Masteratarms93
The 4 terminal connector is for the blower and heater. Which explains why I have no heat lol.
The 3 terminal not used that I can't figure out has 3 wires:
Orange/Red
Black
Red
Old Dec 31, 2012 | 02:08 PM
fmc400's Avatar
fmc400
MSEE
That 4-terminal connector in your last picture is for the ignition module, I can guarantee you that. Three of the four wires in that connector go to the distributor; the fourth goes to the negative terminal of the coil. They do not touch the heater in any way.
I cannot explain the colors for the 3-terminal connector. The 1976 factory diagram claims you should just have RED with a BLUE stripe wire (hot-in-START) and BLUE (hot-in-RUN). The only thing I can think of is it's actually a late-model 1975 harness, which would have 3 wires running to this connector. However, I don't have access to the 1975 factory diagram.
2011FX2Crazy
2009 - 2014 F150
Oct 7, 2020 05:20 PM
N8RdaGR8R
Apr 6, 2019 01:52 PM
1976 Highboy Ranger
Oct 6, 2014 01:57 PM
teds74ford
Dec 20, 2012 11:32 PM
Aaron-71
Electrical Systems/Wiring
Jul 22, 2012 02:07 PM
