Fuel Problem
Old Dec 30, 2012 | 02:45 PM
SouthernBlues's Avatar
SouthernBlues
Fuel Problem
I thibk that my fuel pump is going bad. Engine hardly runs and stalls when you give it gas, changed the filter but did not fix the problem
Old Dec 30, 2012 | 10:54 PM
AndrewW's Avatar
AndrewW
Have you checked to see how much PSI your pump/pumps are putting out?
Old Dec 30, 2012 | 11:01 PM
SouthernBlues
About 15-20 PSI
Old Dec 30, 2012 | 11:08 PM
AndrewW's Avatar
AndrewW
Yep, fuel pump isn't putting out enough. What size engine do you have?
Old Dec 31, 2012 | 04:37 AM
SouthernBlues
4.9 300 6 Cyl. How much of a PITA is it going to be to change
Old Dec 31, 2012 | 09:36 AM
Scott Phillips's Avatar
Scott Phillips
fuel problem
drop the tank or raise the bed. special tool to unhook lines. !
$150 for the pump. major pita
Old Jan 26, 2013 | 05:40 PM
SouthernBlues
Truck back on the road after fuel system repairs. 2 New Pumps,1 Sending Unit, 1 New Tank
mphurlbert
Feb 26, 2014 04:56 PM
rondawgg1118
Feb 11, 2007 09:30 PM
krzyk26
Mar 29, 2005 05:49 PM
bronco2va
Bronco II
Feb 2, 2005 07:41 PM
classicfordluvr
May 9, 2001 08:38 PM
