351m dead hole
Old Dec 29, 2012 | 09:18 AM
lasthighboy's Avatar
lasthighboy
351m dead hole
i did a compression test yesterday on a stock original 351m. numbers were 95 to 125 (which i assume is normal wear), except cylinder #8 wouldnt even read on the gauge (starts at 25). Guessing it had maybe 5-10 psi because it did have some pressure when i released it. Is this a common problem on these motors or do i need to just look for basic mechanical issues? i did not do a leakage test to locate the problem or pull the motor apart to look. The engine will be rebuilt anyway i was just curious. i know it could be burnt or stuck valves, hole in piston, or even broken rod. i just wondered if anybody else has seen this what it might be. thanks
Old Dec 29, 2012 | 10:54 AM
mark a.'s Avatar
mark a.
Take the valve cover off and make sure there the intake valve is opening. Could be bent push rod of something.
'77F250C
May 1, 2019 01:51 AM
northerndave
29
Aug 5, 2012 07:45 PM
Brad 61
Feb 28, 2005 11:36 AM
Ray71
Jun 19, 2004 01:19 AM
bboomer
Jun 8, 2004 04:34 PM
