The diff between wet & dry is good, I have a van with one low reading and it still runs great. If you don't feel it don't fuss. How many miles on it? Get some manifold vacuum readings, somebody was passing around a very good vacuum diagnostic chart maybe Montana.
If I were you I would swapp the heads out. Like you say it's only a little time and some gaskets. What's the point of having sweet duel exhaust if you don't like the way it sounds. Good luck and keep us posted.
Head swap sounds like an easy fix if it is valve springs, I think if it was a ring issue your wet and dry would be DRASTICALLY different, pluss if you pop that head off you can atleast inspec cylinders 1-4, also do you burn any oil, like are you down a quart every oil change? If not i really think this points to the springs and not a ring issue.
northern dave, Do you have a balance tube between the exhaust pipes? If not add one after the heads are swapped , this will smooth out the exhaust sound even more or an "X" pipe. Kenny
A little update here. I inspected one of my spare 351 heads (assembled) and I think I have a winner.
Valves aren't sucked up into the seats, springs look good, I poured a little brake fluid into the exhaust ports with the head face down then checked on the head a little later. I got some minor seeping (a little wet areound the exhaust valve inside the combustion chamber) but the fluid definately didn't run through.
I repeated with the intake side and it was the same or better.
So, I'm thinking I'll lap these valves and stick this head on the truck on my 1,2,3,4 side of the engine.
I tore down one of my "spare heads" tonight, cleaned and lapped valves/seats, measured my springs, cleaned all my gasket surfaces.
Look at this nasty intake valve! The stem seal was shot, drinking oil down the guide. Ick.
unlapped seats.
Lapped seats
Nasty valve on the left, cleaned/lapped on the right
Lapping tool on an intake valve.
They all look like this now, ready to rock.
I measured my free height on my springs, my exhaust springs look to be .037", .030", .024" and .045" short.
I'd shim them if new springs from rock auto weren't so damn cheap. $1.78 each :grin:
So, I'll order some gaskets, some springs and stem seals and I think I'm going to go through my other spare head and swap them both out as long as I'm doing this.
I've also learned that the heads i'm going to toss on my 77 have a little different springs/keepers. My "spare heads" are off a 79 bronco and they went to a different spring retainer in 78, well, shorter spring, a rotating spring retainer and different keepers actually.
Actually, i don't think enough people are aware of this.
The exhaust valve springs on 78 and later M engines will coil bind at .490" valve lift.
So, if you install an aftermarket cam that aproaches .500" gross lift on the exhaust valves, You're going to bend pushrods. (if You have the later style exhaust valve spring system)
