Wet Float setting????
Old May 26, 2003 | 10:15 AM
liljpy's Avatar
liljpy
Does anybody know, or can tell me where to find the wet float setting for a stock 2bbl carburator w/manual choke, out of a 76' F-150 w/ a 360??
Old May 26, 2003 | 09:05 PM
lee's Avatar
lee
Hi,
Sorry I won't be much help here as I am not familiar with your model carb.
Anyway, does the carb have a sight glass on the bowel? If so I believe you want the fuel level half way acreoss the sight.
Or, does the bowel have a plug on it's side like a Holley? If so you want to adjust the float so that fuel just barely trickles out the hole when the plug is removed.
These suggestions may not apply to you but I thought I would throw them out just in case.
Good luck,
Old May 26, 2003 | 09:15 PM
liljpy's Avatar
liljpy
nope, nothing like that, its a very basic H stock motorcraft carb. I am having probs and i think its fuel related so i decided to bend the float cause the fuel level looked high. Well, now i am curious what it is supposed to be. How do you tell if the fuel level is high/low enough? i would really hate to unbolt the damn thing and turn it upside down to do another dry measurement.
Old May 26, 2003 | 11:06 PM
Ford_Six's Avatar
Ford_Six
Try this site, Bubba's M-block Workshop. He has a 2150 carb tech page, and there might be something of assistance there.
Old May 27, 2003 | 09:31 AM
tgregoire's Avatar
tgregoire
If it's a 2100 style carb you can just unbolt the four top screws and remove the top of the carb. Then fire up the truck and check the float level. I use a dial type vernier and measure from the top of the aluminum carb housing to the front edge of the float.
2speed
Nov 16, 2010 04:43 PM
dl1663
13
Nov 17, 2008 04:21 PM
51f1
Oct 3, 2004 10:43 AM
wckdclwn911
May 29, 2004 11:40 AM
liljpy
May 27, 2003 01:44 PM
