FE's dimensions?
Old May 26, 2003 | 09:41 AM
nevrenufhp's Avatar
nevrenufhp
FE's dimensions?
It's a long story, but does anyone have measurements of an FE? I'm looking for oil pan to carb and balancer to bell housung measurements. Also if someone out there has the frame rail width of a 67-72 f100 it would be much appreciated! Doesn't a standard FE weigh about 600 or so pounds?
Old May 26, 2003 | 11:13 AM
dinosaurfan's Avatar
dinosaurfan
FE's dimensions?
Yeah, they are big and fairly heavy, about 600 lbs. If you need the measurements, grab a tape and go out and measure. The FE is slightly shorter and narrower than the 429/460 engine. But the exhaust port angle means FEs need some extra room around the sides for the engine to breath nicely. What are you planning on dropping one into ? DF
Old May 26, 2003 | 12:45 PM
nevrenufhp's Avatar
nevrenufhp
FE's dimensions?
it's the other way around, I'm swapping into the '72. Don't have set plans yet, just ideas. Nepwew's rig, my labor
masterbeavis
17
Nov 3, 2007 03:46 PM
fishinnutinwis
Mar 20, 2004 04:37 PM
jowilker
Sep 22, 2001 08:23 PM
rwjr
Jul 26, 2001 08:19 PM
FE427TP
Jul 18, 2001 03:43 PM
