code P1132, no symptoms? need advice
Old Dec 28, 2012 | 06:34 PM
bigwhitetruck01's Avatar
bigwhitetruck01
I Have an '01 Ex 5.4 V8. The SES light came on today. Autozone says the code is P1132. The truck idles and drives as normal. I've noticed no symptoms or experienced any problems. What should be my next course of action? Obviously I don't want to jump right into throwing parts at the truck to try and figure out the solution.
Old Dec 28, 2012 | 08:38 PM
jh818's Avatar
jh818
Try cleaning your MAF sensor and reset the PCM
Old Dec 29, 2012 | 07:10 AM
bigwhitetruck01
Great, i'll try cleaning the MAF. One of the only other pieces of info I could find was to also try cleaning the IAC. So what is the proper procedure to reset the PCM?
Old Dec 29, 2012 | 07:29 AM
Money-Pit's Avatar
Money-Pit
Disconnect the battery
Old Dec 29, 2012 | 07:46 AM
golfmedik's Avatar
golfmedik
I believe you have to leave it disconnected for a couple of minutes to get it to reset. Not absolutely sure though.
Old Dec 29, 2012 | 10:01 AM
jh818's Avatar
jh818
Yes. Disconnect the negative terminal before you begin removing MAF for cleaning. By the time you are done cleaning it, enough time would have elapsed. It's also good practice to disconnect the battery when working on anything electrical to prevent shorting something out by accident.
Good luck. Hope it works out for you.
Old Dec 30, 2012 | 12:02 PM
bigwhitetruck01
Cleaned the MAF while battery was disconnected. The light hasn't come back on after letting it.idle for a while from dead cold to running temp. Its just too cold outside to attempt an IAC removal and cleaning. I will however be doing that if we get a bit of warm weather.
97_blue_oval
3.8 & 4.2L V6
Feb 16, 2009 10:25 PM
penman39
1983 - 2012 Ranger & B-Series
Mar 15, 2007 08:55 PM
jim001
Aerostar
Mar 26, 2005 02:31 PM
mikegolfnut
1997 - 2003 F150
Jul 28, 2003 04:25 PM
