Aerostar Ford Aerostar
help code 173
Old Mar 23, 2005 | 07:27 PM
jim001's Avatar
jim001
help code 173
Im getting a code 173 along with this code im getting terriable milage, I just did the tune up on it and it did need one. However the engine light remins on.
It is a 94 4.0 with 122000. any help would be greatly appreciated.
thanks in advance
Old Mar 23, 2005 | 08:31 PM
93nighthawk's Avatar
93nighthawk
Code 173-HEGO sensor indicates system rich (RH).
If it is the original O2, I would say it is time to replace it.
I would also clean the MAF sensor.
Old Mar 23, 2005 | 10:14 PM
b2trausch's Avatar
b2trausch
Could be the fuel pressure regulator. Caused the same code on with my 93.
Old Mar 24, 2005 | 12:53 AM
krankshaft's Avatar
krankshaft
Also be sure to reset the computer after you perform the repair by disconnecting the battery for 2 mins. If the engine light remains on you still have the computer is still picking up an error.
Old Mar 26, 2005 | 02:31 PM
himthere's Avatar
himthere
My 94, 3.0, 186,000 mi., intermittently gave codes 172 and 173. (O2 sensor not switching, is or was running lean or rich.) Changed O2 sensor, no more codes. A little better gas mileage also. Real easy to do. Didn't even have to jack it up. Needed a pipe wrench to unscrew the old one, that was the only difficulty. Reachable from the ground on the passenger side.
