Need mods and advice
Old Dec 28, 2012 | 03:58 PM
allhuntalltime's Avatar
allhuntalltime
I have a 99 f350 SD 4X4 crew cab long bed with 371k on it stock except in 99 when I bought it I put a mid range Eldorado Sports super chip in and 285/75/16s. Have had very little trouble with the truck and want to do some useful mods on it. I dont know what I should do first. I do pull a 11,000 camper and other trailer as well. Any ideas on what needs to be done and how it will be useful and how to do it. Thanks for any advice.
Old Dec 28, 2012 | 04:14 PM
BigAlsPSD's Avatar
BigAlsPSD
What do you want out of your truck? That helps with a direction for mods. If you just want some longevity mods, consider the hutch, 50 cent, FRx, valve body, 6.0 trans cooler, and gauges.
Kdr358's Avatar
Kdr358
Gauges to monitor EGT's Boost and Trans temp. I would not advise running a chip without those. Also a John Wood Valve Body would wake up the old tired transmission. the hutch mod would probably benefit you.
Old Dec 28, 2012 | 04:28 PM
allhuntalltime
These sound good is there somewhere on this site that explains these and how to do them.
Old Dec 28, 2012 | 04:37 PM
429 f-100's Avatar
429 f-100
GO TO THE FIRST THREE THREADS AT THE TOP, THE ONE THAT SAYS 75000 VEIWS GENERAL TECH I THINK LOTS OF INFO THERE.
Old Dec 28, 2012 | 04:45 PM
BigAlsPSD's Avatar
BigAlsPSD
There are different ways to do a "hutch" mod, but this is the idea. Welcome to guzzle's In-tank Hutch Mod Web Page personally I didn't use the large filters, I just ran a inline filter before the pump on the frame rail.
The 50 cent mod, is putting a slightly ground down quarter under the clips for the UVCH(Under Valve Cover Harness) to keep them from coming loose.
Here's a couple different valve body write ups Welcome to guzzle's BTS Valve Body Web Page Riffraff Diesel: John Wood 4R100 Valve Body http://www.riffraffdiesel.com/mm5/RE...structions.pdf
Here's the FRx Riffraff Diesel: Fuel Rail Crossover™ http://www.riffraffdiesel.com/mm5/RE...structions.pdf
Here's Ken's(Woodnthings) 6.0 installation https://b7445ba3-a-62cb3a1a-s-sites....attredirects=0
Here's some popular gauge setups Riffraff Diesel Performance Parts: - Packages http://www.riffraffdiesel.com/mm5/RE..._Gauge_Pod.pdf http://www.autometer.com/download_instruction/828d.pdf
mud dawg 89
Computer Chips & Tuners
Feb 21, 2009 11:26 PM
aussie01
May 12, 2008 11:19 AM
blrman1962
Oct 8, 2007 03:06 PM
tmoore6135
May 25, 2006 10:09 PM
craziejoker
Mar 23, 2006 06:53 PM
