Starter problems
Old Dec 28, 2012 | 12:05 PM
caspersrevenge1's Avatar
caspersrevenge1
Question Starter problems
Hi,everyone.I am new here and I hope I have this in the right category.I just bought a 1981 F150,351M-automatic.When I start it ,the starter stays engaged and running even after I turn the key off.The only way I can stop the starter is to remove -battery cable from battery post ,but if I try to put cable back on.it sparks.
Old Dec 28, 2012 | 01:24 PM
joerickson's Avatar
joerickson
Sounds like it needs to either be rebuilt or replaced.
I believe when the solenoid goes bad, its fails to disengage the starter gear. I may be wrong, but then again I'm no expert.
Old Dec 28, 2012 | 04:25 PM
redsuperduty's Avatar
redsuperduty
Don't buy a starter, it's working fine.
Replace the solenoid, the contacts are sticking in it.
Old Dec 28, 2012 | 05:07 PM
big ole ford's Avatar
big ole ford
try pulling the wire off the terminal marked S if it still acts up replace the solenoid if it doesnt first try switching the S and I terminals(if it has a wire on the I terminal) if not replace the ignition switch
Old Dec 29, 2012 | 11:22 AM
caspersrevenge1
Alright,thanks everyone.I will check those things and get back with you.
Old Dec 30, 2012 | 10:55 AM
caspersrevenge1
O.K.,I replaced the solenoid and it is working fine. Thanks for all the help.
fordatic
Sep 23, 2016 01:28 PM
court1100f
18
Apr 9, 2014 11:22 PM
BostiPB
1978 - 1996 Big Bronco
May 25, 2011 09:29 PM
savag
Feb 19, 2011 03:11 PM
bjwq45
13
Jul 12, 2008 02:41 PM
