I don't know what your plan for brake mods are, but if you can, get the power brake booster/master cyl and pedal assembly.
Not the antilock stuff, just whats on the firewall.
maybe you already got that figured out. but typing is cheap and easy.
If i,m looking at the code correctly looks like the explore rear end is 4.11. Dont think if i,m going to the trouble to change out rear end i will go with something about the same as i got. And as far as disc brakes on the back, guess its kind of a plus but not that big of a deal after i get disc on the front. Thanks for the pictures. This info is going to help me alot. Has anyone used the motor mounts for a SBC that attache to the frame and do away with the cross member?
