Explorer rear end years
Old Nov 3, 2014 | 07:48 PM
Bigfreeb's Avatar
Bigfreeb
I want to pick up an Explorer disc brake rear end but I want the narrow one. Ive looked here and online but can't find a solid answers. Really I just need to know the last year of the narrow I think its 2000 but not sure. My 2001 Sport trac is still the narrow and drum I think it changed in 2002. Going to use this for my 1968 F100 build sorry forgot that info!
Old Nov 3, 2014 | 07:57 PM
HIO Silver's Avatar
HIO Silver
'Might be better to post your q in the explorer or an xj forum.
Old Nov 3, 2014 | 08:00 PM
Bigfreeb's Avatar
Bigfreeb
OOPs I forgot to say that my plan is to use it on my 68 F100 when I build it but good idea I will post over there also.
Old Nov 3, 2014 | 08:12 PM
ultraranger's Avatar
ultraranger
The Explorer rear end prior to 1995 had drum brakes. The Explorer from 2002-present has an IRS rear end.
The Explorer 8.8" solid axle housing rear end with disc brakes, that you are looking for, would come from a 1995-2001 model.
These ('95-'01) all have 31-spline axles and disc brakes. Not all came with a Traction-Lok differential but, 3.55, 3.73 and 4.10 ratios are pretty common in them.
The '96 Explorer rear end I have stashed back doesn't have Traction-Lok but, it does have 3.55 gears. --Traction-Lok differentials for them are relatively cheap to purchase and install, if the rear end you get doesn't have one.
Rear end codes:
Axle Tag Codes for Ford Explorer, Ford Ranger and Ford Bronco II Axle Identification
Old Nov 3, 2014 | 09:00 PM
Bigfreeb's Avatar
Bigfreeb
Ultraranger that is what I was looking for. Thank you!!
Old Nov 4, 2014 | 10:59 PM
youngone1234's Avatar
youngone1234
Are they a direct bolt in to the 67 72 f100s or do you have tab up stuff to make the rear end fit in. Just curious.
Thanks Pat.
dferrell5
30
Jan 25, 2014 01:26 PM
HEAVY100
15
Oct 24, 2011 04:12 AM
ckltrk
Feb 23, 2008 04:47 PM
