Resistor wire
Old Dec 27, 2012 | 02:08 AM
BigB9000's Avatar
BigB9000
Resistor wire
So, I pulled the Wiring out of my 75 f-100 today to replace some pigtails, and just clean everything up.
I have 2 stray wires that don't go anywhere, one I don't care about right now, and the other, is a damn resistor wire.
So, under the broken resistor wire, is another 'loop' that also says its a resistor wire. 2 wires???? From all I have read there is only supposed to be one.
I needed a new ignition switch pigtail (someone just shoved the wires into the switch) and a steering column pigtail. So I headed over to the pick a part and got some.
Found a pigtail that had a resistor wire sharing the large ground, so I grabbed it, and guess-hooked it up to my mystery resistor wire
Discovered wire that didn't go anywhere:
(arrow is the resistor wire, question mark is the other wire, know what it does? Im guessing ciggy lighter)
And, here is where I hooked it up too:
(see the large black wire, sharing a terminal? thats where)
Is this correct?
Keep in mind, the truck ran with out this wire hooked up.
Old Dec 27, 2012 | 07:32 AM
teds74ford's Avatar
teds74ford
I can't really remember much on my 74s wiring since I did it years ago, but I just redid the wiring on my 79. The cigarette lighter wiring is green/yellow.
As far as the resister, it's purple, right? I believe it just runs in the harness for a while and eventually feeds the gauges. I have to check on that, but for now, here's a link to some really good factory wiring schematics:
1973-1979 Ford Truck Wiring Diagrams & Schematics - FORDification.net
Old Dec 27, 2012 | 08:38 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Does your truck have a warning light rather than an ammeter? If you do then the black resistor wire is probably circuit 96. It runs from the warning light's connection at the PC plug on the back of the instrument cluster to the ignition switch where it is paired with the black wire w/ green trace.
Old Dec 27, 2012 | 10:50 AM
BigB9000's Avatar
BigB9000
Thanks for the reply, but I need the year that isn't listed
It does have warning lights!
So, I probably did it right?
Ill pull out the mulitmeter and see if it leads to the cluster.
Old Dec 27, 2012 | 02:54 PM
teds74ford's Avatar
teds74ford
I know it doesn't show 75, but I think 73-75 are very similar.
I don't know how you would fix the resistor wire. I tried to when I converted my 77 harness to use my 74 gauges and it was a pain.
Blue and White
19
Aug 31, 2025 06:49 PM
RandyP63
May 2, 2016 11:55 PM
grinnergetter
Oct 12, 2011 09:53 PM
dnrast
Electrical Systems/Wiring
Oct 31, 2004 06:25 PM
Brent
Nov 8, 1999 12:30 AM
