pre built "hutch" kit.?.
Old Dec 26, 2012 | 06:30 PM
the78ranger's Avatar
the78ranger
I know dieselsite.com used to sell a complete kit with external filter to do this mod, but I just looked on their website and can't seem to find it. So my question is do any of you guys know if any other site has this available?
2000 cc sb 4x4 4r100
Old Dec 26, 2012 | 06:51 PM
srteach's Avatar
srteach
Driven Diesel Fuel Tank / Pre-Pump Kit Is the one I put on two different trucks. Both worked great and are currently in use.
Old Dec 26, 2012 | 06:58 PM
PaysonPSD's Avatar
PaysonPSD
If you are on a budget you can go this route. Diesel Innovations. I installed this kit in Dec 2007 and have only had to change the pre-pump filter a couple of times.
Old Dec 26, 2012 | 07:00 PM
the78ranger
you are awsome srteach!!!! I now have no idea why I thought dieselsite.com, when actually it was strictly diesel I was looking for. Thanks
Old Dec 26, 2012 | 08:44 PM
srteach's Avatar
srteach
Glad I could help.
Old Dec 26, 2012 | 08:51 PM
Joe28443's Avatar
Joe28443
Joe28443
Does the kit from diesel innovations come with everything you need to install? Why just so cheap? is it the filter type?
Old Dec 26, 2012 | 09:05 PM
PaysonPSD's Avatar
PaysonPSD
When I bought it was 25 bucks and 10 bucks more for stainless steel.
You will have to supply your own line to move the return line away from the pickup. I used a piece of brake line from napa. Forget the size and length. I also used the 90° elbow from the removed mixing chamber to reroute the return line.
I always thought I would upgrade to a spin on water separator filter, but only if I did a fuel bowl delete. Well, I still have the stock fuel bowl and the DI kit is still there and problem free. I see no air passing through that see-through filter.
Old Dec 26, 2012 | 09:09 PM
srteach's Avatar
srteach
The driven diesel one I posted above is complete with everything you need.
Old Dec 29, 2012 | 08:59 AM
Joe28443's Avatar
Joe28443
Joe28443
Thanks for the input, I should be able to use guzzles parts list to get what I need for the return line.
Old Dec 29, 2012 | 07:00 PM
1fixitman's Avatar
1fixitman
You will need the 3/8 and 5/16 fuel line disconnect tools to get the connections off the top of the fuel tank. 3/8 for supply line and 5/16 for the return line. You can get the plastic disconnect tools also which may be a bit cheaper. Here is the link to the metal ones from harbor freight. 4 Piece Fuel and Auto Trans Line Disconnect Tool Set
Nabors
25
Oct 28, 2020 02:53 PM
JT250
20
Apr 3, 2012 07:03 PM
szotty
30
Jan 31, 2011 06:27 PM
markjw
Dec 12, 2008 04:31 AM
Ehammond
20
Aug 13, 2007 01:20 AM
