Blinker problem
Old Dec 26, 2012 | 05:42 PM
the_game_rock's Avatar
the_game_rock
Blinker problem
We pulled the dash and replaced the blend door. Now after we put it back together. Blinkers, hazards and brake lights (bottom ones) quit working. The 3rd brake works. If you push in the hazard switch all the brake lights work. If you have the hazard on, whatever side turn signal you have on while pushing the brakes that brake wont light up. (example push brake, use right signal and hazard on the right rear brake wont light up.) All fuses and relays are good. They changed out the turn signal switch piece in steering column. Wiring was looked over. Any ideas?
orlando.ortiz3
Mar 15, 2018 12:27 PM
rezdawg
Oct 9, 2012 12:05 PM
kermmydog
Nov 12, 2006 11:34 PM
Galizien
Oct 3, 2006 03:29 PM
BigEd73Highboy
Sep 12, 2002 12:41 PM
