Kinda no start.
Old Dec 26, 2012 | 10:34 AM
pin8246's Avatar
pin8246
Kinda no start.
Cold first morning 24 degrees and no start. First issue with mine I've had ever. It cranks and starts but automatically dies. Ideas?
Old Dec 26, 2012 | 10:44 AM
pin8246's Avatar
pin8246
Alright ford started. Had to floor the pedal to get started, and it finally stayed started. Warming up now. Should I replace anything gpcm or glow plugs?
Old Dec 26, 2012 | 02:15 PM
Brother Les's Avatar
Brother Les
This is a diesel pump injected, I don't think flooring it will do a whole lot of good. The fuel injectors are opened by oil pressure. If the oil is too thick because of the cold they may not open very fast. Put a lighter weight oil in it or put a timer on it to heat up the oil about two hours before you need it. Make sure that your batts are in top shape, get them load tested. Since it started being this cold, I would think that the glow plugs came on. Did you 'wait to start'? Cycle the 'wait to start' twice and see if that will help it start better.
Get a volt meter that plugs into the accessory port. It will show you your batt voltage and the drop when your glow plugs come on and when the glow plugs shut off and also the out put voltage of the Alternator.
Old Dec 26, 2012 | 02:26 PM
pin8246's Avatar
pin8246
Yea thats sounding right. It did get started with the pedal floored, but this was after 4-5 cycles of the wait to start, so prob just looked at it the wrong way. But once it got started, I could floor the pedal, and it would barely rev up. So with what you said, I would say the oil was thick. Its usually kept in the shop, but right now I got so much going on in there im leaving it outside. I run the same oil all year round for the simple fact that down here in Texas, this cold rarely happens.
Old Dec 26, 2012 | 02:35 PM
Brother Les
You might do a test and see if some of your glow plugs are not working (or gpr). 24degrees is really not that cold for these trucks if all of the GPs are working fine. cycling 4-5 times may be couple two many .
get the plug in volt meter from wally world and see how far the voltage drops when the gpr comes on.
Old Dec 26, 2012 | 09:38 PM
pin8246's Avatar
pin8246
No walls world here, I'll see what I can find.
Old Dec 27, 2012 | 05:52 AM
Christof13T's Avatar
Christof13T
dont worry too much about it pin... Motorbug did the same thing yesterday morning. puking white smoke initially is normal too... until it starts and begins warming up... then the smoke should clear. if you plug in your block heater you should eliminate most of your hard starts...
flatbed444E
17
Mar 20, 2015 09:34 AM
honeydew
23
Aug 19, 2013 11:12 AM
srkr
6.7L Power Stroke Diesel
19
Sep 27, 2011 06:00 PM
Jager
17
Nov 29, 2010 08:31 PM
78f3504x4
Nov 17, 2005 09:57 PM
