Heater/ac issue
Old Dec 26, 2012 | 09:59 AM
Jamie Arceneaux's Avatar
Jamie Arceneaux
Heater/ac issue
I am having a bit of trouble with my heater/ac mode switch I believe. No matter what position i put the switch on it only blows through the defroster vents. The only other position that works is off. When it is on off then it doesn't blow out of any vents. Does this sound like the mode switch itself or an actuator or something like that inside the system? How tough is it to remove the dash to get to this switch if it is just the switch?
Old Dec 26, 2012 | 10:04 AM
dsquared's Avatar
dsquared
Vacuum leak in the ESOF hubs... Usually the hoses running to them....
Old Dec 26, 2012 | 10:06 AM
Jamie Arceneaux
ESOF Hubs? What the heck is that?
Old Dec 26, 2012 | 10:11 AM
dsquared's Avatar
dsquared
I'm guessing (MY BAD) you have 4WD; it is the Electronic Shift On the Fly hubs. They are vacuum operated. when they start leaking, heater/AC defaults to defrost. If you don't have 4WD, time to look at another vacuum line I guess...
Old Dec 26, 2012 | 10:14 AM
Jamie Arceneaux
ok. No, mine is a 2wd. When this happened with my jeep it was just the switch but I will start looking at a vacuum leak i guess. It's not that big of a deal except my feet are cold!
Old Dec 26, 2012 | 02:09 PM
SpringerPop's Avatar
SpringerPop
Don's got you on the right (vacuum leak) track.
The Federally-mandated "default" failure mode is Defrost. That's all the Feds consider to be absolutely necessary.
Even though you're freezing, you legally have to be able to see out the windows!
Pop
Old Dec 26, 2012 | 02:11 PM
Jamie Arceneaux
Well the windows are great so the Feds will be happy. My Towson the other hand…lol
Old Dec 26, 2012 | 02:50 PM
SpringerPop
First, make sure your vacuum pump runs. That's where you get your vacuum, as diesels don't have any intake manifold vacuum. The truck still needs vacuum to run the HVAC controls and baffle servos..
Pop
Old Dec 26, 2012 | 02:54 PM
snknby123's Avatar
snknby123
as others have stated it sounds like a vacuum issue. Do a search and you should find plenty of info on this issue.
Old Dec 26, 2012 | 03:13 PM
officer131's Avatar
officer131
There is a little plastic piece on the passenger side fender (vacuum solenoid) i think. Had to replace mine and heat/ac was working as it was supposed to.
Old Dec 27, 2012 | 05:39 AM
Liquid10Rider's Avatar
Liquid10Rider
When I first bought my truck it had this issue found out that the vaccum pump was n/g. replaced it and havent had any issues. If you need one 1aauto has one with lifetime warranty. I had one fail, called them up and they sent me a new one no questions asked.
hope this helps,
-AJ
Old Dec 27, 2012 | 07:46 AM
Jamie Arceneaux
It was a fuse to te vacuum pump. The different part is that you couldn't tell the fuse was broken from looking at it. An ohm meter on te fuse confirmed the circuit was broken and a new fuse got it going.
deemac
Feb 13, 2012 05:18 PM
Ryank78shortbed
Aug 22, 2011 09:57 AM
78bigunns
Jul 10, 2011 09:28 PM
CaptKirk
Aug 15, 2010 11:17 PM
bigoguide
Oct 23, 2007 02:34 PM
