Battery charge question
Old Dec 25, 2012 | 11:19 AM
guitarpicr's Avatar
guitarpicr
Can I charge my batts without disconnecting them, while hooked up in truck or should I disconnect & charge one at a time. Ya- They were stone cold dead this morning.
Old Dec 25, 2012 | 11:36 AM
Punisher29073's Avatar
Punisher29073
That should be fine.
Old Dec 25, 2012 | 11:42 AM
JT250's Avatar
JT250
It is better to separate according to my battery store.
Old Dec 25, 2012 | 12:01 PM
crop harvester's Avatar
crop harvester
if I thought there was a problem with one of the batteries, I would charge sepperate, if batteries were down due to lights etc left on then I would charge together.
Old Dec 25, 2012 | 12:12 PM
guitarpicr's Avatar
guitarpicr
ok- thanks guys - they are 5 years old so thinking they are about due. Had,nt started truck for a couple weeks prior to this
Old Dec 26, 2012 | 02:26 PM
Brother Les's Avatar
Brother Les
the red flag is why were they stone cold dead? Even worn out batts should not have been 'dead' after two weeks of sitting. Either way, time to change out after 5 years imo.
Old Dec 26, 2012 | 03:55 PM
guitarpicr's Avatar
guitarpicr
Les- I had been working on the truck over the past week or so & was playing the radio & doors & hood open without starting it. I left the charger on it for 5 hours & fired right up. I'll see how she does after a good run on the highway to recharge them. I am due for new batts b4 any major trips are planned.
Old Dec 26, 2012 | 05:10 PM
xbox73's Avatar
xbox73
You can charge the batteries in the truck without disconnecting, but may work better to disconnect depending on the charging capability of your battery charger. My little 1 amp charger never reached the float state, even after 2 days, with everything still connected, though it did charge the batteries significantly. I then bought a 5A charger, and that was much quicker & did reach the flat state within 24 hours (may well have been sooner, I wasn't actively monitoring).
Also, if charging the batteries in the truck, with everything still connected, some battery charger manufacturers recommend you connect the charger across both batteries (i.e. + alligator clip from charger on + terminal on one battery, - alligator clip from charger on the - terminal of the OTHER battery).
Old Dec 26, 2012 | 05:29 PM
PaysonPSD's Avatar
PaysonPSD
I disconnect the driver side postive cable and charge that batt. When it is done I just leave the driver side negative hooke up to charger and hook the positive of the charger to the lifted cable to charge the passenger side. After they are both charged I leave the cable lifted for several hours and check each battery level to make sure they are both close to equal voltage before I reconnect. This way I only half to mess with one connection.
Olds69442
6.7L Power Stroke Diesel
Dec 23, 2012 06:17 PM
FSJ-EARL
Jul 29, 2012 12:55 PM
Waynenap
34
Apr 19, 2011 10:40 AM
KMUL
Jan 27, 2009 09:04 PM
cjspack
Jan 31, 2007 10:25 AM
