Another GPR question
Old Dec 26, 2012 | 04:12 PM
TXdoug's Avatar
TXdoug
I got a little chilly here last night (29*). This am no start, tried about 30 min. then popped the hood. No voltage on the go side of GPR. I jumped the relay with pliers for 30 sec. and she started with a little romp.
Later I switched over to the IAH relay. I did not switch the hot leads. Are these are the same or is there a reason to switch them also? I tried to test it but it is all warmed up now.
I am thinking about doing the light but for now I just wanted to see if the extra relay is going to work.
Old Dec 26, 2012 | 06:08 PM
lhud's Avatar
lhud
I just got through installing the Stancor unit I have had all summer. It is really heavy duty compared to the OEM and other replacements. You can search for instructions on FTE and its very easy.
I would also add the LED light on your dash somewhere - this told me right off the bat that my relay was not operating from a cold start. No more wandering and getting the VOM out to check the GP side - if the LED is on you know there is voltage to the GP's.
Old Dec 26, 2012 | 06:16 PM
dmanshane's Avatar
dmanshane
Yes go with the stancore I love it... I also mounted my gp light on my water temp gauge bezel down by the 4x4 shifter
Old Dec 26, 2012 | 06:51 PM
TXdoug's Avatar
TXdoug
Thanx guys,
I just wanted to make the most of an under used relay. I was reading about the LED light when I remembered these. I bought them years ago with hopes of lighting up the ash tray.(another story).
I pulled one out and wired it up as per the directions available here. I pulled off the big removable panel below the steering wheel and had easy access here.
Ground lugs are right there too. First try it lit for about 90 sec. then start. next try only about 70 sec. Looks like we are A OK.
I do love this FTE thing, This am my truck did not start and cuz of yall I knew where to look. Now it is fixed and improved and I did not spend a penny.
Old Dec 26, 2012 | 07:13 PM
PaysonPSD's Avatar
PaysonPSD
The always hot leads on the GPR and the AIH are common.
The switched hot leads are not. If all you did was swap the GPR control leads to the AIH relay then when
the AIH relay operates as the GPR it will send power to the manifold heater element and not to the GPs.
To use the AIH as the GPR you should remove the GPR and mount the AIH relay it it's place.
Be sure you insulate the AIH always hot lead and the control leads. OR put the GPR in place of the AIH
relay to have a place to safely attach the AIH always hot lead and control leads..
Remove both positive battery leads before working on the GPR or the AIH relay.
adam10
Apr 23, 2012 10:41 PM
6.9idiatsturbo
Apr 19, 2012 09:06 AM
brownie83
Mar 1, 2010 10:51 AM
dyoungen
Jan 22, 2010 09:14 AM
00Dave
Dec 16, 2009 01:50 PM
