I have a 2000 with a automatic in it and it is going out and I want to put a six speed in it and I was wondering how hard it would be and if there is a kit or what all parts i will need any help will be great
I am not aware of any kits for a swap, but i am pretty sure you are going to need another PCM from a manual truck to start with. Way cheaper to fix the auto.
you will need a donor truck for parts. trans, pedal assembly, steering column, computer, floor pan, crossmember, and probably driveshaft just to name a few things.
I have a 97 manual could I use any thing off of it the 5speed went out in it so we are just gonna take tho motor out when mine goes would any parts of the Trany work to make mine to a manual
