Undercoating good or bad?
Old Dec 23, 2012 | 11:13 AM
rob92761's Avatar
rob92761
Has anyone in the northern states undercoat your truck. Does it help in the long run against rust protection? Especially if you keep your truck for a long time.
Old Dec 23, 2012 | 11:45 AM
69cj's Avatar
69cj
If done properly it can help. If done halfa** it will create pockets for moisture and salt to accumulate and make things worse. Undercoating is also a major pain if you have to work on, disassemble, parts that have been coated.
Old Dec 23, 2012 | 12:12 PM
Hdslider's Avatar
Hdslider
And it does void your body corrosion warranty..
Old Dec 23, 2012 | 12:39 PM
rob92761's Avatar
rob92761
That interesting because the dealer was trying to up sells me on it
Old Dec 23, 2012 | 12:48 PM
rob92761's Avatar
rob92761
Straight from ford wed site!
The New Vehicle Limited Warranty does not cover surface rust, deterioration and damage of paint, trim, upholstery, and other appearance items that result from use and/or exposure to the elements. You, as the owner, are responsible for these items. Some examples are: • dings, dents
• cuts, burns, punctures or tears
road salt • tree sap, bird and bee droppings
• windstorm, lightening, hail
• earthquake
• freezing, water or flood
• stone chips, scratches (some examples are on paint and glass)
• windshield stress cracks. However, limited coverage on windshield stress cracks will be provided for the first 12 months in service, regardless of miles driven, even though caused by use and/or exposure to the elements.
Old Dec 23, 2012 | 12:49 PM
los341's Avatar
los341
I had my truck undercoated the day I bought it. I don't see how it would void warranty since the dealer contracts with this same agency. I've seen plenty of examples of undercoating vs not undercoating and there is no doubt that undercoating prevents rust!
Carl
Old Dec 23, 2012 | 01:25 PM
RM2738's Avatar
RM2738
Doesn't cover SURFACE RUST, but I believe they do cover corrosive rust.
Old Dec 23, 2012 | 02:41 PM
Grunttorque's Avatar
Grunttorque
We've been taught at work that the auto industry is moving away from undercoating because it makes rust worse. It's not a corrosion protector and actual absorbs moisture and creates corrosion. especially if you've driven in salt at all and apply it over the dry salt. Plus In my opinion it just makes a mess of everything
Old Dec 23, 2012 | 11:16 PM
los341's Avatar
los341
If you've driven in salt before having it undercoated, then I'd suggest washing the salt off first
Old Dec 23, 2012 | 11:21 PM
Grunttorque
Most people don't even know that they've driven in salt when they have.
Old Dec 24, 2012 | 07:02 AM
senix's Avatar
senix
best pm is to wash weekly...the undercarriage. Use fluid film before winter sets in and spray the underside down.
pdqtimetrialer
2004 - 2008 F150
Aug 16, 2011 07:36 PM
honda4x4nut
May 18, 2008 06:52 PM
hdman6
Sep 10, 2007 08:37 AM
JFUSION
Escape & Escape Hybrid
Dec 5, 2006 06:58 PM
acslim
General Automotive Discussion
Nov 1, 2005 06:05 PM
