Does the Map sensor have anything to do with the EBRP sensor? Alright, these are the details. Block heater pulled in all night, cold start with driving right after. I go easy on the throttle. It comes and goes but sounds like air rushing under the hood. Somebody said my EBP valve might be sticking. When it happens it feels like a loss of power, but if I accelerate more it will kick in and drive normal. Found out today the line to my MAP sensor was cracked where it connects to the intake Y. Could that have been what is causing the noise? Or was it just a fluke?
The map sensor i believe is only used for fuel mapping, nothing related to ebpv. If you have ever blown the line off the map sensor it will barely move out of its way going down the road, so if under slight throttle if it is cracked and leaking it could cause a loss of power until you give it throttle and your boost over comes the leak, however that problem shouldnt come and go, it would be a constant problem. To me it also sounds like a sticking ebpv, try unplugging the connector on the pedestal before your next drive, if the problem stops you know the ebpv is the problem.
Thank you very much Robin. If it is sticking, what is the best fix? I am believing thats what it is because come to think about it the truck doesn't go into the jet engine sound exhaust when it is cold anymore. It does slightly but nothing like it did before I replaced the sensor and tube.
Thanks Robin for the picture, and i know, ive been tied up with so much moving to nevada for awhile, then back to tn, getting married and property now, its good to be back
Seth, if you remove the valve, just give it a good cleaning to get all of the built up soot and deposits out of it
Congrats Cory. She's a lucky woman, and you're probably an even luckier man.
Okay. So the valve can be removed. I am guessing that is pretty straightforward as to how to do it. Unlike the connector which I can't even get to it with my arms to disconnect. Gonna had to take a intercooler pipe off to get to it. Probably will just clean it while I am there and see what happens. Thanks again Robin. Does anybody have a write up on cleaning the valve?
The EBPV is in the turbo exhaust housing. The only way to get to it without removing the turbo is to remove the exhaust down pipe.
Even then there is not enough room to really clean it.
What you should due first is disconnect the EBPV actuating rod and work the valve open and closed to see if it is sticking. The rod is held to the pivot pin with a sliding clip. You have to push the clip back to disengage the rod from pin. The rod drops down to disengage.
