There is no Radiator Inter cooler, Ac condensor, Steering cooler. Just A fan behind the Grille!
Good catch!!... I used to live in Descanso, Then moved down the hill to Alpine. I wonder whos truck that is (everyone knows everyone up there). Wonder if I could find out more about it??
<a href="http://zaazu.com"><img src="http://images.zaazu.com/img/Private-Eye-private-eye-detective-sherlock-smiley-emoticon-000745-medium.gif" width="81" height="79" border="0" alt="http://zaazu.com" /></a>
Looks road hard put away wet! My opinion too much money for all the work that will be needed. If they didn't care about the outside I'm fairly confident they didn't change the fluids either.
RR tire looks bent (could just be the rear axle on a slope), front end impact in the past, would worry about heat damage if it was run without radiator.
Somebody used that for parts... hence, no rims. The passenger side is beat, the front bumper is caved-in, the passenger-rear fender is bent upward, the rear bumper is bent backward, there's no grill (as well as all the missing cooling stuff), and the tires are flat... but I'd bet that's not why they trailered it. Any wagers on how much of that carnage was in a single serving?
I don't see 4k there... Not in that shape. It's worth a core charge on the engine and that's about it IMO. If you knew the engine and trans was good, maybe more. Then again, how does he know the computer went out?
