6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
codes
Old Dec 21, 2012 | 06:03 AM
magum350's Avatar
magum350
codes
does anybody have the codes for 2008 6.4L and can you post them,my truck check engine lite just came on scaned and found P0106 I believe that has something to do with coolent temp but not sure.2008,F350,crew cab ,6.4L,34,800 milews.
Old Dec 21, 2012 | 07:04 AM
senix's Avatar
senix
P0106 X
Manifold Absolute
Pressure/BARO Sensor
Range/Performance
This diagnostic compares MAP and BP pessures at idle
conditions, when they should be within a specified range.
This error is set if the MAP sensor reading is above or
below the thresholds for a predetermined period of time.
N > function of (ECT)
Vehicle speed =0
ECT> 70 deg C
10% < EGRTP command <100%
no DPF regen requested
for > 10 seconds
300hPa or -300hPa >5sec
Wiring, MAP sensor, BP sensor
(intergral part of PCM)
Old Dec 21, 2012 | 09:01 PM
RM2738's Avatar
RM2738
Google
Old Dec 22, 2012 | 08:12 AM
magum350's Avatar
magum350
thanks for the reply on my code,glad it's nothing real serious
Old Dec 22, 2012 | 08:59 AM
senix's Avatar
senix
sounds like a sensor issue only
Old Dec 22, 2012 | 11:00 AM
magum350's Avatar
magum350
yes I guess so,I cancled code has not come back on yet
System
6.7L Power Stroke Diesel
32
Jan 2, 2021 12:50 PM
lstitt
Australia Chapter
Dec 22, 2015 02:43 AM
Jerry Chaney
Mar 19, 2014 01:02 PM
CPFR1924
Aug 23, 2011 02:52 PM
glasseater
Oct 26, 2008 08:55 PM
