429 come in a 1979 f250 from factory?
4x4's didn't come with the 429 or 460. If it's a stock truck, then it's either a 351 or 400.
The only difference between a 429 and a 460, is the stroke. The 429 has a shorter stroke than a 460. Everything else is the same. No trucks came with 429's, only 460's. There would be no way to tell just by looking at it.
Now if you want to know if its a 351/400 or a 429/460, look at the valve covers.
351/400
429/460
Jameson
351/400
429/460
Jameson
The 4th digit of the VIN is the engine code: 1977/79 F150/250 4WD, 1979 F350 4WD:
B = 300 I-6 was standard equipment / H = 351M & S = 400 were optional (have 8 valve cover bolts per side).
No 460's came with a manual trans or 4WD until 1983, and then in F250/350's only. 429/460's have 7 valve cover bolts per side.
Alaskaman
29
09-01-2017 10:27 PM
96-5spd302
03-26-2004 07:37 PM
