ECT too low
Old Dec 20, 2012 | 05:45 PM
davbeisner's Avatar
davbeisner
ECT too low
Ok, on my '06 F-250, when I test drove it before buying it I could never get my ECT over 180. In the two months I've had it, I only got it to go over 180 once, and that was towing a 7000# trailer up a 7% grade about 7 miles. At that time it got up to around 203 when the fan kicked on (seemed really low temp for fan based on other reports).
I assumed it was my t-stat, so replaced it today while doing a coolant change/flush. But it's still not getting much over mid-170s with highway driving, even going WOT in passing.
Any other things that could be keeping that temp down? Ambient air temp is about 10 right now, FWIW...
Old Dec 20, 2012 | 06:49 PM
Mich6.0's Avatar
Mich6.0
Have you changed out the temp sensor ? Could be bad
Old Dec 20, 2012 | 07:54 PM
davbeisner's Avatar
davbeisner
Not yet... Sensors appear to be okay... ECT and EOT match ambient after long cold soak.
Old Dec 20, 2012 | 07:55 PM
davbeisner's Avatar
davbeisner
Fwiw, I plugged up AE today instead of my SGII and got readings around 185 after 20 minutes of high idle. Interesting that SGII and AE would report differently, since they are both sending what the PCM sees.
Old Dec 20, 2012 | 08:22 PM
Yahiko's Avatar
Yahiko
Did you program the ECT or use the pre-programed one ?
If you did the programing than it could be a goof in the coding.
My SGII is not right when it reports battery voltage/ It's about 0.5 V off
Sean
Old Dec 20, 2012 | 08:38 PM
davbeisner's Avatar
davbeisner
I'm using the preprogrammed one... fWT
Old Dec 21, 2012 | 08:04 AM
Misky6.0's Avatar
Misky6.0
After letting your truck sit for 12-24 hours....
compare your ECT, EOT, and TFT readings in the SG2...
They should all be within a degree or two of each other, mine are
pretty close most of the time.
Ambient temp changes do effect each fluid slightly different, so if you
wait until it warms up (10 AM) they might be slightly more separated.
Old Dec 21, 2012 | 08:22 AM
davbeisner's Avatar
davbeisner
Yeah, I checked them about two weeks ago. After 36 hours all were within 1 degree... Temps now are dropping well below 0 at night, so it stays plugged in.
Old Dec 21, 2012 | 10:29 AM
Mich6.0's Avatar
Mich6.0
Are you running 5w-40 synthetic, really helps in cold weather and runs quieter,no romp when cold even it is not plugged in
Mich6.0's Avatar
Mich6.0
rhrs2414
Mar 24, 2016 02:07 PM
tcatrider_99
Aug 26, 2014 06:40 AM
ROBBINthaHOOD
Mar 17, 2013 12:09 PM
Benchwrench
Aug 28, 2008 04:20 PM
trencherman
Apr 16, 2007 06:50 AM
