351 surging at idle.
Old May 25, 2003 | 03:42 PM
garryk50's Avatar
garryk50
'92 f-150 surges while idling. Any ideas why? Can't find any vacuum leaks and I don't have $10,000 worth of diagnostic equipment.
Old May 25, 2003 | 05:39 PM
pfogle's Avatar
pfogle
try cleaning the IAC (little silver canister looking thing on the RIGHT side of the throttle body as you look at it with wires hooked to it.) Buy a haynes manual, it has the procedure for pulling the codes. Buy the manual at 12 bucks instead of a 25 dollar code reader that you DO NOT need. You have a check engine light so you can use it instead of the code reader.
Old May 25, 2003 | 10:56 PM
FlaresideGlenn's Avatar
FlaresideGlenn
My 1990 Mustang 5.0 developed a surge at idle last summer. I couldn't figure out what was wrong - no apparent vacume leaks, etc - so I took it to a garage I know.
They pluged into the car's computer and there was a code flashing - what they said was the computer simply needed to be "re-set" after it got a bad code or something.
$20 later - its ran great since then.
Hope that helps,
Glenn
Tim Hodgson
1978 - 1996 Big Bronco
Jan 6, 2015 12:43 AM
cory5517
Oct 13, 2012 08:55 AM
cajunsuperduty
Oct 28, 2011 03:31 PM
ClubDrof
Nov 17, 2004 08:51 PM
scroogetrades
Bronco II
13
May 31, 2003 12:22 PM
