Surging at idle
Old Sep 2, 2012 | 05:46 PM
cory5517's Avatar
cory5517
Surging at idle
What causes a 7.3 to surge while idling?
Old Sep 2, 2012 | 11:44 PM
Bonanza35's Avatar
Bonanza35
What do you mean surge? It could be alot of things. Clean your throttle pedal sensor with some contact cleaner and see whats happens.
Chet
Old Sep 2, 2012 | 11:50 PM
Hawk180's Avatar
Hawk180
Does it do it while it is cold, but go away when it warms up a little? If so, be sure you have the correct weight of oil in it. Mine did and I cured it by switching over to 5W40 Rotella T6 Full synthetic. Now it idles smoothly cold or warm.
Old Sep 3, 2012 | 07:28 AM
cory5517's Avatar
cory5517
I cleaned the throttle pedal sensor last week but didn't fix the surging or vibration. It does it if the engine is hot or cold. I'm Currently running delo.
Old Sep 3, 2012 | 09:32 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Check your ICP sensor....
It's on the front of driver side head and has a connector going to it. Inspect the plug, if there is oil on it, replace the sensor. Leave it unplugged and start the truck. If the surging stops, then for sure replace the sensor.
Old Sep 3, 2012 | 09:34 AM
cory5517's Avatar
cory5517
I'll try that thank you
Old Oct 12, 2012 | 09:50 PM
00Dave's Avatar
00Dave
Hey Cory, did you figure out your issue? I have the same situation where mine slightly surges @ idle, no matter warm or cold.
Old Oct 12, 2012 | 10:18 PM
fordpride's Avatar
fordpride
Unplug the ICP and see if it stops
Old Oct 13, 2012 | 07:25 AM
cory5517's Avatar
cory5517
Haven't been able to check, got injured at work and had my arm in a sling ever since
Old Oct 13, 2012 | 08:55 AM
Christof13T's Avatar
Christof13T
Had a similar issue on motorbug. Turned out to be my ebpv fluttering. Disconnected and the surging stopped.
mike71800b
Nov 18, 2017 10:38 AM
LIGOOMBA
Apr 7, 2009 01:47 PM
fordguy55
1983 - 2012 Ranger & B-Series
May 20, 2008 09:51 AM
Red Raider 4x4
Oct 30, 2005 06:21 PM
Nitramjr
Aug 25, 2004 04:26 PM
