Sponsored by: Auxito
Slow electrical Drain
Old Dec 20, 2012 | 12:13 PM
Forger's Avatar
Forger
I have a 97 F150 with a 4.6. Dont like the thing much but im selling it so I need to fix this problem. Whenever i leave it sit for more than 24 hours the battery dies. The battery, alternator and starter have all been tested and all check out good, (including checking for surface load on battery) Now when I turn the truck off (and take the key out) there is a whinning noise on the driver side of the throttle body. Im thinking its related, but i havent gotten around to figuring out what this stupid thing is, Its got on electrical connector to it and three vacuum lines.
Old Dec 20, 2012 | 12:30 PM
projectSHO89's Avatar
projectSHO89
That noise is just the EVR solenoid bleeding up manifold vacuum. It's normal.
Old Dec 20, 2012 | 12:39 PM
Forger's Avatar
Forger
Damn, I was hoping that was my leak. Alright thanks. Dont suppose theres a common drain I can start with.
Old Dec 20, 2012 | 01:26 PM
enriched&beyound's Avatar
enriched&beyound
do you have aftermarket security system or remote starter?
Old Dec 20, 2012 | 02:07 PM
projectSHO89
Underhood and glovebox lamps are the most common ones that can't be easily seen.
Old Dec 20, 2012 | 09:05 PM
Forger's Avatar
Forger
The guy I bought it from had a dixie horn, cab lights, and an after market stereo installed... I checked the lights then this slush storm hit us, so I guess we'll see if that fixed it. Im going to check other the other things tomorrow, as well as the other lights.
gravduvall
19
Apr 6, 2018 11:27 PM
4speedspring
23
Sep 26, 2016 10:16 PM
Scott Sheridan
Apr 5, 2013 09:48 PM
tonka96
Apr 15, 2011 07:28 PM
GOTH_TRUCKER
Aug 3, 2006 03:23 PM
