battery drain
Old Aug 2, 2006 | 09:00 PM
GOTH_TRUCKER's Avatar
GOTH_TRUCKER
Exclamation battery drain
ok,i have a slight problem,ok,when i try to start my truck it turns over real well then it just slows way down,the starter to clarrify.and i checked batteryvoltegde while sitting is 12 v then while crnking it drops to 4v so i pulled the starter and got it checked and the bearings were gone,so i am just wonder wut else do i replace for this problem?thx ya'll
Old Aug 2, 2006 | 09:58 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Replace the starter, and see if it still has the problem. I think the problem would go away.
A starter with bad bearings. (that's what you said right? ) would cause a lot of draw on your battery.
If the problem persists have the battery tested, and replaced if necessary.
Also check your battery cables. If they look brittle, cracked or corroded, replace them.
Hope this helps.
Old Aug 3, 2006 | 03:23 PM
GOTH_TRUCKER
man idk wut i would do with out ur help thx
