Battery Drain
Old Apr 5, 2013 | 02:30 PM
Scott Sheridan's Avatar
Scott Sheridan
Battery Drain
I have an 03 7.3L, and I am having a small battery drain of around 100 milliamps. I pulled all of the fuses in the fuse box last night, and nothing killed the battery drain. At this point I am wondering if I have a bad ground connection. Has anyone had experience tracking down all the possible ground connections I should check? I am assuming I at least need to start with the alternator and starter.
Old Apr 5, 2013 | 08:47 PM
EpikExcursion's Avatar
EpikExcursion
Do you have TV's...bigger stereo...AMP steps or anything that could draw amps by chance
Old Apr 5, 2013 | 09:35 PM
Scott Sheridan
There is an alpine system, a DVD player in the ceiling, and a remote starter. I figured if any of those systems were the issue that I would see it when pulling the fuse for the circuit they are on.
Old Apr 5, 2013 | 09:45 PM
JWC 3's Avatar
JWC 3
A ground issue should not cause an amp drain . If all factory components have been ruled out , look at aftermarket accy. Disconnect Each component one at a time , Keep Alive also ! , and see what happens to the draw .
Old Apr 5, 2013 | 09:48 PM
JWC 3's Avatar
JWC 3
Note , I stated Keep Alive . Many aftermarket devices have extra power connections for that function . They may be hidden and not connected to the fuse box .
vjsimone
6.4L Power Stroke Diesel
Jun 16, 2013 01:41 PM
Mike in Ohio
Feb 29, 2012 06:50 PM
amos truckalot
Jun 29, 2010 07:57 AM
Deac1970
1978 - 1996 Big Bronco
Jan 11, 2006 07:45 AM
johnanderson
Electrical Systems/Wiring
Jan 6, 2004 03:43 PM
