Will not move!
Old Dec 21, 2012 | 11:37 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
Originally Posted by midapo
Can you recommend a source for a heavy duty torque converter? Thanks for the help!
i use this Eagle X4TC;
https://racerxusa.com/index.php?cPat...9bd9a39af46440
you need to understand,that if the converter failed,it likely spread its guts throughout the trans.see here:
https://www.ford-trucks.com/forums/1...some-pics.html
Old Dec 21, 2012 | 12:06 PM
CampSpringsJohn's Avatar
CampSpringsJohn
Originally Posted by FORDF250HDXLT
That would be a great upgrade. Which one do you use?
Never mind! I see!
Old Dec 21, 2012 | 06:06 PM
midapo's Avatar
midapo
Those converters look really nice. That's what my mechanic told me too, that the torque garbage will be spread thru the whole transmission and it will have to be cleaned thoroughly. I did mention to the mechanic about the upgraded torque and he highly recommended it. The tranny shop has one that they use, so I'll just go with that. Those pictures are something. I sure hope the tranny shop cleans it good!
Old Dec 29, 2012 | 10:09 AM
midapo's Avatar
midapo
Update: The tranny shop finished my rebuild. They said the torque converter pretty much blew up. They install heavy duty torques in all their rebuilds, 12 month 12000 mile warranty. Cost for the rebuild $1898.80. I pick it up monday.
Old Dec 29, 2012 | 10:21 AM
CampSpringsJohn
Let us know how you like at after you put some miles on it! Thanks for the update!
Old Dec 29, 2012 | 10:47 AM
FORDF250HDXLT
isn't that something.just a little over 100k miles it says in your signature too.glad i just bit the bullet and swapped mine out.i had planned to get a dump trailer (which i did a little while ago) so i knew i better replace the oem converter first.
well,a couple grand and a fresh trans,you should be good to go for the rest of the trucks life really.i guess they're all rebuilt to a min of '94 (or '95,i can't remember all this stuff lol) specs these days.so that's a plus.
Old Dec 29, 2012 | 08:16 PM
midapo's Avatar
midapo
I hope your right, friend. I would like for this to be my last truck!
Old Dec 29, 2012 | 09:01 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
what do you have for a trans cooler? if you have an aux cooler i would replace it since there will be junk from the converter in there as well.
Old Dec 29, 2012 | 09:36 PM
CampSpringsJohn
Standard operating procedure for replacing a transmission does include flushing out the transmission lines and cooler. So that shouldn't be a concern unless that was not done. Or, is it possible for stuff to be stuck in there after flushing the cooler and lines?
Old Dec 29, 2012 | 09:44 PM
'94IDITurbo7.3
you can't truly flush a trans cooler. besides for the little price(compared to a new trans) it is just cheap insurance to buy a new cooler. you will never get all the stuff out of the aux cooler just b/c of the design. the cooler in the rad will be just fine if you flush it.
Old Dec 29, 2012 | 09:59 PM
CampSpringsJohn
Is that because of all the turns in the lines and perhaps some low spots? I've never heard this before, but it does make sense, assuming you and I are now on the same page.
Old Dec 30, 2012 | 04:09 PM
'94IDITurbo7.3
i don't know for sure but i would have to agree with you on all the twists and turns in an aux cooler.
Old Dec 30, 2012 | 10:46 PM
  #28
midapo's Avatar
midapo
I do know they flushed the system. I am not sure if they replaced the cooler. I will have to check on that.
saltbranch
Mar 2, 2016 09:00 PM
greenf150flareside
19
Jul 31, 2015 08:59 PM
andydunks
Feb 6, 2015 04:12 PM
BillyBob69
62
Dec 12, 2010 08:42 PM
BlackNGoldRules
1983 - 2012 Ranger & B-Series
Aug 11, 2008 08:38 AM
