One big screw up!
Old Dec 23, 2012 | 04:13 PM
Fordworth's Avatar
Fordworth
That ain't bad. I brought mine back from this with junkyard parts and a MIG welder.
That's a front D60 snapped in two. The rear one was bent pretty bad too.
Old Dec 23, 2012 | 08:15 PM
PaytonK.79Ford's Avatar
PaytonK.79Ford
Fordworth, I didn't do quite as bad as you but I still didn't do too hot. Just pulled my truck out of the shop from a rebuild and brand new paint and drove it for a week with everything going good. Pulled in into the shop to do some carb tuning, reached in the door to fire it up...... and it was in gear.
Didn't hurt the bumper but knocked out my park light, wiped out a fender, and wrinkled my grille shell pretty good. Luckily, I had a good fender laying around, leftover paint, and a buddy with an extra park light. And the wrinkle in the grille popped right out.
Old Dec 24, 2012 | 01:34 AM
Fordworth's Avatar
Fordworth
Ouch.
The paint on mine is only six months old in the pics. I used the opportunity to do a custom build so all in all it worked out.
Old Feb 24, 2013 | 02:30 PM
tater_51's Avatar
tater_51
Finally, a good day
Finally got my truck back, over 2 months in the shop (it's winter here so I wouldn't be driving it anyways!). They welded pins all the way down the side and eased it all out, able to keep all the original metal, lots of blocking and they did a beautiful paint match. Now it's time to finally pull the 360 and put the 416 in, it's been on a engine stand for 2 years. I'm getting older and these projects worry me a little more than they used too. I'll post my progress.
Old Feb 24, 2013 | 02:41 PM
AK FORD GUY's Avatar
AK FORD GUY
Glad you got it back and things worked out.
Good luck on the engine swap. Did you build up a bored out 410, or did you get the 416 going another route?
Old Feb 24, 2013 | 08:00 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Glad the shop did a good job .
Old Feb 24, 2013 | 09:19 PM
tater_51's Avatar
tater_51
About 2 years ago I picked up a 410 on Craigslist. It was at a machine shop in Ohio. All the work had been done, bored .030 over, new pistons, heads gone over with new valves, springs, all surfaces cleaned up, a real nice long block, minus cam. I think it was a "fail to pay" by original owner. I tore everything back down and took it to the shop I use, Baker Engineering. Had block and crank magnafluxed, everything rebalanced with new flywheel and dampner. Went with a crane cam (still in business then), stock intake (4V) with autolite 4100. Just came in from shop tonight. Have radiator out and starting to strip things down. I sure like Western Trucks, very little rust/corrosion, things come apart nicely.
Old Feb 25, 2013 | 12:37 AM
AK FORD GUY
Sweet, I have an autolite 4100 as well. I was was thinking about putting it on my truck until I was informed that they don't like the cold weather much. I'll save it for a summer vehicle project.
Old Feb 25, 2013 | 10:13 PM
tater_51's Avatar
tater_51
box nuts???
Well.......all was going pretty good tonight, got down to the last exhaust manifold bolt and"snap", good thing this motor is coming out, should not be to hard to drill out. Read about someone just taking out a couple hood hinge bolts, leaving one in and rotating the hood back, laying the hood back on the truck, sounded good to me. First hinge bolt I tried to get out just spins, looked underneath and it looks like (for lack of a better term) a box bolt. The nut must be rounded off inside and just spins. I assume the only thing I can do now is cut the bolt and see if I can get underneath and cut the box off then just use a regular bolt/nut. Anyone else have this problem? Solutions? Looks like the hood will be coming off anyways. Hope that the nuts on the inside of the hood are in better shape than the hinges. All in all a pretty good night.
greywynd
16
Jan 5, 2012 10:18 PM
Epd444
16
Dec 5, 2008 04:19 PM
Code3
South Carolina Chapter
Apr 16, 2007 11:47 PM
desertford
2004 - 2008 F150
Apr 10, 2007 08:12 AM
BlueOvalBoy
Garage & Workshop
51
Feb 12, 2004 12:27 AM
