GP harness question
Old Dec 17, 2012 | 06:46 PM
mrberg89's Avatar
mrberg89
GP harness question
So I was putting new ends on the glow plug harness and decided to test the continuity of the harness. Disconnected all the connectors. Between the bullet connectors and the z bar terminal on the relay I had good continuity.
I then decided to check between the bullet connectors and ground and found that they all had some continuity to ground. I then checked between the z bar terminal and ground and had continuity there as well.
I found out that if I removed the green wire from the z bar terminal, that I would have no continuity between the bullet connectors and ground.
What gives? Is this normal? I figured there should be no continuity between the bullet connectors and ground.
Thanks
Old Dec 18, 2012 | 02:25 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
for ground,check between battery and ground terminal not the test terminal (z bar.)
Old Dec 18, 2012 | 07:28 PM
mrberg89's Avatar
mrberg89
I wasn't checking for ground at the relay though. I was checking to see if my glow plug harness has a short to ground. Should it?
Old Dec 18, 2012 | 08:48 PM
FORDF250HDXLT
no,you don't want the wires that supply power to your plugs grounding out.
"So I was putting new ends on the glow plug harness and decided to test the continuity of the harness. Disconnected all the connectors. Between the bullet connectors and the z bar terminal on the relay I had good continuity. "
your test passed there.
your next test will be the ground as mentioned,then the voltage supply test at the test terminal.
check this out for the complete run through:
https://www.ford-trucks.com/forums/1...low-plugs.html
Old Dec 18, 2012 | 10:24 PM
mrberg89's Avatar
mrberg89
My problem is I have continuity between every glow plug connector and ground. It only goes away if I remove the green wire.
I should disregard this and go on to the next test?
Old Dec 19, 2012 | 01:09 PM
Dark Horse's Avatar
Dark Horse
Below is a Schematic for the Glow plug circuit:
I don't recognize the green wire but maybe this will help.
Mark
Old Dec 19, 2012 | 05:52 PM
mrberg89's Avatar
mrberg89
I don't see the green wire on the schematic. Thanks though.
The arrow in this picture is pointing to the green wire I'm talking about.
It shows continuity to ground when tested. Looks like it goes to the controller. Is this normal?
Old Dec 20, 2012 | 12:47 AM
Dark Horse's Avatar
Dark Horse
Read this thread it should tell you every thing need to know about the glow plug circuit:
https://www.ford-trucks.com/forums/9...le-system.html
Mark
Old Dec 20, 2012 | 06:30 AM
mrberg89's Avatar
mrberg89
I read the whole thread and saw no mention of whether the green wire should show ground or not.
Thanks though.
Bender99
Sep 20, 2010 10:04 PM
tommyj92028
Dec 19, 2006 10:22 AM
yellow401
Nov 13, 2006 11:41 PM
Drover
Apr 14, 2005 10:36 PM
DaveSmith
Sep 16, 2001 12:20 PM
