DieselRx glowplugs
Old Dec 17, 2012 | 12:09 PM
cowmilker08's Avatar
cowmilker08
DieselRx glowplugs
I see that rosewood is selling DieselRx glowplugs. Has anyone tried them?
I wonder how they do over time or if they get stuck when you try to pull them out?
Old Dec 17, 2012 | 12:39 PM
427 fordman's Avatar
427 fordman
Jim says they are good plugs, and they probably are. I however will always stay with what I know works and won't swell. Motorcrafts.
Old Dec 17, 2012 | 01:18 PM
Talyn's Avatar
Talyn
They are good plugs.
I believe Jim told me he's had no issues with them for a number of years.
They burn a bit hotter as well.
Old Dec 17, 2012 | 02:32 PM
glovemeister's Avatar
glovemeister
I'll stick with Motorcraft/Beru. Typically I know the aftermarket can do it better, but I don't want to take a chance with them swelling in my heads.
Old Dec 17, 2012 | 03:22 PM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
You certainly cannot go wrong with Motorcraft.
Personally, when my truck was 5 years old I had 2 Motorcraft stuck in the heads and I had to pull the heads to get them out.
So I don't put as much faith in them as many other people do.
But they are as good of quality as you'll find and I personally think the DRX and Bosch are right up there, too.
I sell probably 50 - 60 sets of PSD DRX plugs a year and have only had an issue with the IDI plugs, that run on 5 volts.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Dec 17, 2012 | 11:36 PM
ProjectDually's Avatar
ProjectDually
What's the bench test compared to OEM? They should have something you youtube and people that have used them, but not necessarily in this platform, but should yield similar results.
I' got a set of GP's for my 2.5TDI Audi A4, not DRX, but a good aftermarket, something in german I can't spell for you, and It seemed like in the deep colder weather, cranking time was lowered, and GP cycle was faster, more heat, and maybe only took one or 2 cycles to turn over in the -30C weather( in Germany).
If you get them, let us know your results, after all this base stupid stuff I keep getting gigged on, I can start the Engine Overhaul part of my project.
Old Dec 18, 2012 | 12:15 AM
glovemeister
Here is a good link on the GP's, although in a different application.
Whats the best glow plug for the cucv
Old Dec 18, 2012 | 01:53 AM
Ford4Life7.3's Avatar
Ford4Life7.3
Check this out- It compares them to Beru's and NGK's. Now heres the thing...they state in the video that the reason DRx Gp's are better is because the heat is concentrated at the tip of the GP. To me, that says it all when the issue we face is the tips of the gp's swelling and becoming lodged in there. Repeated heating and cooling of just the tip (or HOTTER at the tip) would seem to encourage this happening, am i wrong?
Old Dec 18, 2012 | 02:36 AM
glovemeister
DieselRx Glow Plug Comparison - YouTube
Diesel R/X is also known as Wellman, brand plugs.
I'm not too certain on the theory behind the plugs, but I would guess Jim could chime in here on that. If says they are good to go then I wouldn't have an issue with running them.
Old Dec 18, 2012 | 02:49 AM
Ford4Life7.3
[QUOTE=glovemeister;12611175]Diesel R/X is also known as Wellman, brand plugs.
I'm not too certain on the theory behind the plugs, but I would guess Jim could chime in here on that. If says they are good to go then I wouldn't have an issue with running them.[/QUOTE
Its nothing to do with Jims word on whether theyre good or not, i trust that haha. Its just to me, the reasons they cite as what makes them better is what we've all been told (and it makes sense) that makes them cause problems.
Old Dec 18, 2012 | 02:56 AM
glovemeister
[QUOTE=Ford4Life7.3;12611182]
Well, my personal opinion follows yours. Its just that if that was the case, wouldn't Jim as well as others be posting all kinds of stuff on them swelling?
WXboy
2009 - 2014 F150
Feb 22, 2016 06:01 PM
Sycostang67
13
Jul 26, 2009 10:00 PM
86OldBlue
2004 - 2008 F150
Jul 14, 2009 10:05 PM
gtex
Jun 20, 2004 06:30 PM
tapenick
Nov 22, 2003 07:29 PM
