75 F100 4x4 SWB u-joints
I think just about every u-joint in my truck has about had it... I can find the store brand chinese parts & numbers from the different big box parts stores but wanted to go with spicer u-joints. Can anyone confirm the spicer part numbers for the rear & front drive shafts and the front axle? Its all stock as far as I can tell and I wont be doing anything the stock configuration can't handle; if I do I will deal with it then.
I did enough searching and put this together...
Spicer 1310 series is used in all 4 driveshaft joints.
Spicer 760x series is used in the front axle.
Plz advise if I am wrong... The purpose of this is so I cab source online; parts in general seem to be cheaper when you arent fixated on the vehicle application but rather the individual component number.
Bad Bad Leroy Brown
10-22-2012 07:28 PM
