Fuel tank selector
Old May 24, 2003 | 10:37 PM
dan_da_mick's Avatar
dan_da_mick
Fuel tank selector
Has anyone had the fuel tank selector valve go out on their truck?
I have an '87 F150 4x4 with dual tanks. It won't run off of the rear tank. I pulled the supply line from the rear tank off of the selector valve. With the truck running, I switched over to the rear tank and gas gushes out, so it seems the pump works, although I haven't taken a fuel pressure measurement.
It seems like a simple enough device that wouldn't be prone to failure, but I can't think what else it would be.
Old May 25, 2003 | 11:18 PM
steve83's Avatar
steve83
Fuel tank selector
There are several threads about that valve, and at least one includes general instructions on disassembly & repair. It might be in the fuel forum.
Old Jun 12, 2003 | 01:27 PM
rugerj's Avatar
rugerj
Fuel tank selector
I am having similar problems and have read many many posts but am unable to find this post demostarting how to remove/repair the slector valve. Can someone out there point me in the right direction? Thanks.
Old Jun 12, 2003 | 02:08 PM
jbalestri's Avatar
jbalestri
Fuel tank selector
Make sure it is the valve, and not the switch first.
Old Jun 13, 2003 | 01:30 AM
ludis's Avatar
ludis
Fuel tank selector
Make sure you don't have one of the defective valves. The "fixed" part number starts with F1U. Several years worth of trucks were recalled (I think, or perhaps just a TSB) to replace defective valves.
Old Jun 13, 2003 | 06:47 AM
rugerj's Avatar
rugerj
Fuel tank selector
I will checkout the part number first, thanks for the advice. I am thinking it may be this piece because when I switch tanks the fuel gauge reads full (I have just topped off the tank) but it continues to pull gas from the front tank. If not I will start diagnosing the both the low pressure tank pumps first and work my way forward. Another question. Would the high pressure pump be the only reason why I have to crank the engine for about 5-7 seconds first thing in the morning to get it started. I think that the fuel pressure is droppping overnight and the fuel is bleeding back towards the tank. It starts fine for the rest of the day. I know i do not have a physical fuel leak anywhere because I don't see any spots on my garage floor in the morning.
Old Jun 13, 2003 | 10:10 PM
steve83's Avatar
steve83
Fuel tank selector
Since the truck runs on the wrong tank, it sounds like your switch (in the dash) may be bad & not actually switching the pump power. It could be that the hi-pressure pump is pulling fuel from the wrong one because the selector valve (on the frame rail) isn't switching, but most people's trucks stall when that happens. Verify WHICH lo-pres pump is getting power when the dash switch is set for the rear tank, and try tapping on the selector valve to get it to change over. Marvel Mystery Oil (MMO) in the gas may loosen it up.
Old Jun 14, 2003 | 11:32 PM
ludis's Avatar
ludis
Fuel tank selector
The selector valve on these trucks isn't powered. It uses the pressure from the selected in-tank pump to switch.
Old Jun 15, 2003 | 12:38 AM
steve83's Avatar
steve83
Fuel tank selector
Yeah, but they gum up - that's why MMO may loosen it up and allow the meager pressure from the tank pump to switch it, and tapping may help.
jb10725
Oct 14, 2014 08:05 PM
Franken-Truck
Electrical Systems/Wiring
Dec 18, 2011 06:20 PM
cdevor
Sep 15, 2010 08:11 PM
mdm350
15
Mar 16, 2010 09:52 PM
Tennesseeduck
Jul 15, 2007 04:34 PM
