Fuel Gauge Open Circuit Diagnostics Help
Old Dec 17, 2011 | 01:25 PM
Franken-Truck's Avatar
Franken-Truck
1987 F250 carb'd 460, dual tanks
Electric in-tank pumps, 6-line electric selector valve
Both tank pumps work as far as I can hear. Motor runs fine when either tank is selected. The selector switch can be felt operating when the tanks are switched.
My problem is the fuel gauge is pegged past "full" when either tank is selected. At the fuel selector switch, I've grounded the y/w wire and the gauge will peg to "empty". At the selector valve (5 wires), when I ground the rear tank with the rear tank selected it will read "empty" (front tank will read "full"). With the front tank grounded and selected it will read "empty" (rear tank will read "full").
So far from what I could garner off the net and this site, all the wiring is good from the gauge to at least the selector valve and the selector valve itself is good. I assume I have an open circuit between the tanks and the selector valve? Is there anything else I can test, or am I just unlucky enough to have 2 bad fuel senders?
Thanks!!
Old Dec 17, 2011 | 04:37 PM
Franklin2's Avatar
Franklin2
Try to explain that again.
I've grounded the y/w wire and the gauge will peg to "empty". And when you take the wire off ground the gauge goes to full correct? If so, we will call this good.
At the selector valve (5 wires), when I ground the rear tank with the rear tank selected it will read "empty" And when you take this wire off, the gauge goes to full? Then that is correct also.
With the front tank grounded and selected it will read "empty" And when the wire is taken off ground it reads full? If so, that's correct also.
If it all works like the above, and you can do the same at the tank sending unit wires, then it must be the sending units are bad.
Old Dec 18, 2011 | 06:20 PM
Franken-Truck
Groovy, that's how it all works
I need to change out the fuel valve though. I caught the rear tanking pumping into the front tank on Saturday Only done it this once that I know of, but I guess that's enough, lol. . .
Checking the sending units come after. . .need to drop the tanks for that which I'm not looking for
crawlin-kingsnake
17
Jul 22, 2019 11:07 PM
colemanw
Oct 17, 2018 07:21 PM
FORDF250HDXLT
May 11, 2016 07:54 AM
capitan72
Mar 27, 2011 03:57 PM
Gene Marsh
Jul 29, 2003 09:35 PM
