i can't find a 1/8" spot on my engine for oil pressure. And yes i have searched the forum but i havnt found any pictures yet. Please help, it is very much appreciated
Factory oil sender is 1/4,, but where it threads into the block is 1/8. There is also one one the drivers side of the bell kinda that is 1/8 also from the mains.
Your coolant sender didnt come with reducers?
You must not have done a good job searching...
For the oil, look near the oil cooler in the rear of the engine, there are small square plugs. There are pictures of this area if you search.
For the coolant, you have a couple options. Pictures have been posted in 2 threads about this, both in recent weeks, like last week and the week before.
Or where the adapter that comes up in the back by the factory psi guage is, you could just use a 1/4 by x1/8 bushing. Sounds like you have to get one for your temp guage anyway. Any hardware store should have. Galv is fine, brass is better.
