Sponsored by: Auxito
Engine harness power steering assist
Old Dec 14, 2012 | 02:17 PM
Mrkoopa's Avatar
Mrkoopa
I come once again for the knowledge that y'all provide. I'm smack dead in the middle of a engine swap into a 2001 f150 the donor is out of a 99 expedition. Wanting to use the 99's wiring harness which looks the same except for a small connector at the bottom next to the oil pressure sender. I believe it to be a power steering assist. It was a recently rebuilt motor and the harness is pristine. The only question is can I use it, if so do I leave it unplugged or plug it in to the power steering pump? Thanks for your help. ~Steven
Old Dec 14, 2012 | 02:22 PM
MisterCMK's Avatar
MisterCMK
That is probably for a pressure switch for the power steering lines. Is there a switch on the power steering lines?
Old Dec 14, 2012 | 02:25 PM
Bluegrass 7's Avatar
Bluegrass 7
The power steering signal is to tell the computer to account for the extra load the pump will put on the motor when the steering is moved, otherwise you can experience stalling or large idle swings when parking or making slow speed steering changes etc.
Good luck.
Old Dec 14, 2012 | 02:26 PM
Mrkoopa's Avatar
Mrkoopa
No there is some sort of sensor on the power steering pump itself. I just don't know how my PCM will react if this sensor is plugged in.
Old Dec 14, 2012 | 02:41 PM
Mrkoopa's Avatar
Mrkoopa
Ok so if my old motor didnt have it I can just forget about it. ? Or are the pins still there and it's just never had it so would it be ok to hook it up and gain this new feature.
Old Dec 14, 2012 | 02:59 PM
MisterCMK's Avatar
MisterCMK
Just plug it in.
Gwilkrrs
Nov 14, 2017 01:24 PM
Welsch69
Nov 12, 2008 12:25 PM
Olddog66
Apr 27, 2008 07:23 PM
Adriand
Mar 15, 2004 06:14 AM
