Power Steering Upgrade
Old Nov 12, 2008 | 09:57 AM
Welsch69's Avatar
Welsch69
Hello. I have a 1975 F250 4X4 with manual steering. I also have a 1974 F250 2wd with power steering. What would I need to put the power steering from the '74 into the '75? Thanks.
Old Nov 12, 2008 | 11:13 AM
masterbeavis's Avatar
masterbeavis
You need a 77.5-79 steering box, the brackets for the pump, the pump, the steering shaft, the steering linkage to the axle....
73-77.5 were power assist, expensive to maintain, and needed maintenance often, my vote=avoid.
Old Nov 12, 2008 | 11:46 AM
Welsch69's Avatar
Welsch69
Thanks guys. If i chose to keep the power assist, would it bolt straight across onto the '75 4X4?
Old Nov 12, 2008 | 12:25 PM
75F350's Avatar
75F350
You said keep the power assist? Do you have another truck?
Thought you mentioned a 2wd with PS, and a 4wd with a manual box?
Regardless, the power assist is poor. I guess when it works well, it is alright, but it is borderline.
You do want to upgrade to power steering, and as suggested you can use the 78/9 box. This is not a direct bolt in, since the x-member is different from the HB trucks to the later 77.5-79 trucks.
I used a saginaw 16:1 4 turn power steering box for my 74 when I upgraded the steering and converted to crossover steering.
I just had a lengthy discussion regarding the advantages of either steering type, and would simply suggest that you consider all of your options.
You do not necessarily have to convert to x-over, but the power steering upgrade is definately worth the investment.
You do not want to try to scab that super funky 2wd box into your frame rails, this will require some real ghetto fabrication and the frame will have to be cut terribly. I have seen 2wd boxes used in these older trucks, and I heve never seen this accomplished with a positive outcome.
Here is a pic of my box during the install:
Image of saginaw power steering conversion - Photobucket - Video and Image Hosting
