Hello I am looking for some help. Intermittently when truck is cold and I go to start it truck just goes rump and doesn't start. Sounds like a cough. Turn the key again and it starts fine. Second thing is when truck is cold while taking off from a stop truck will stutter or skip a beat. Both of problems are interment and do not do it when truck it warm. Problem is it is starting to happen more and more. Have checked IPR and ICP both are clean and dry. Any ideas? Thanks for any help.
You'll get some answers/questions in the morning I'm sure. I would recommend doing a search on here for for your symptoms to get boned up for the answers to to some questions you will need to answer to help the experienced folk on here focus in on the probable cause.
Good luck and I'll be interested in reading the eventual solution.
does the cold start problem go away whe you plug in block heater,just wondering if the glow plugs are doing there job,could do a voltage drop test on gp relay or bypass with a jumper to see if that helps diagnose.
