Newbie body panel question
Old Dec 13, 2012 | 09:36 PM
eb76adam's Avatar
eb76adam
Searched to no avail - are any of the body panels for the 73-77 trucks able to be used on the 78-79 trucks?
Specifically the split grills using the round headlights?
I have a 78 with the full grill and square headlights.
Grill needs to be replaced - trying to figure out options.
thanks
Old Dec 13, 2012 | 09:43 PM
gpence's Avatar
gpence
You can swap it for the older grill if you want. All the body panels interchange 73-79. Only differance is they put the fuel filler behind a door in 77 & changed the grill in 78
Old Dec 13, 2012 | 09:53 PM
eb76adam's Avatar
eb76adam
Great, thanks.
I assumed as much but figured if I didn't ask before I picked up the new grill tomorrow And find out it wouldn't fit.
Appreciate it.
Old Dec 13, 2012 | 10:27 PM
mikeo0o0o0's Avatar
mikeo0o0o0
If you're going to install the earlier round headlight grill, you'll also need to swap the radiator support.
Old Dec 13, 2012 | 10:45 PM
gpence's Avatar
gpence
Yeah or atleast plan on spending a couple hours fitting & drilling holes to mount the round head light buckets. It's kind of a pain but is doable
Old Dec 13, 2012 | 11:09 PM
eb76adam's Avatar
eb76adam
Ok so ur saying if I swap the radiator support, which should fit as well, I can just bolt it all up and be good?
Old Dec 14, 2012 | 12:26 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Yes, the earlier 73-77 Round headlight, split grill will fit, along with the radiator support.
Old Dec 14, 2012 | 12:30 AM
hairyboxnoogle's Avatar
hairyboxnoogle
I say neither. I put my 77 grille, headlight, turn signals on my 79 in about 45 minutes. Granted i had everything and knew ahead of time what it was going to take. The 78-79 core support has the spots for the earlier round light buckets to go, just not the holes. All you really need are the round headlight buckets and a drill. Pretty easy deal.
Old Dec 14, 2012 | 03:17 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
73-79 fenders, doors, bed sides, tailgate will swap around among years. There are a few year differences in the bed sides and fuel filler neck, but overall the same.
73-77 (round headlights 2 piece insert) outer grill shell will work on a 78/79
78-79 (round 78 and square 79 headlights 1 piece insert) grill shell will work on a 73-77
Like you have just been told, the easier way to put a 77 outer grill shell on a 78/79 and DRILL the radiator core support to mount the round headlight buckets.
Its alot easier than changing the complete core support IMO. Cause them dang 2 bottom bolts/spacer set ups that always rust.
If you are getting a aftermarket grill shell, be ready for lots of $$ and not the best fit from LMC unless you go with Dennis Carpenter I hear on here his are the best.
So all said and done best option is to get a replacement same style outer grill shell and then its as simple as off and back on, no drilling required. Unless you want the older look of a 2 piece insert and round headlights???
Old Dec 14, 2012 | 10:51 AM
eb76adam's Avatar
eb76adam
Thx guys. Good info.
That's the look I'm going for in the pic above on the right. I currently have the setup on the left but its damaged.
Old Dec 14, 2012 | 10:56 AM
77&79F250's Avatar
77&79F250
You can get the headlight bucket assemblies new for $$, or for alot less out of a JY. Measure and take note or digi pic where the old ones are and just drill new mount holes in your same ol core support.
The odd man out IMO, is the 78 with a one piece grill insert and round headlights. My blue rig was like that then the PO changed over to square's.
Old Dec 14, 2012 | 11:08 AM
eb76adam's Avatar
eb76adam
Got another idea....
Can u do the early split grill and fit the larger rectangular headlights in from the 78-79?
Old Dec 14, 2012 | 11:12 AM
77&79F250's Avatar
77&79F250
Would still have to repalce your bad outer grill shell, and then modify a set of inserts to fit around the squares, not to sure how it would turn out look wise??
Old Dec 14, 2012 | 11:15 AM
eb76adam's Avatar
eb76adam
I may have to play with that idea a little. I like the sit grill much better but the larger headlights look more proportional to me.
Thx everybody
Old Dec 14, 2012 | 11:17 AM
earthquake68's Avatar
earthquake68
Here's a step by step to convert the newer grill to the older one.
https://www.ford-trucks.com/forums/1...rill-swap.html
