Tire pressure
Old Dec 12, 2012 | 11:30 AM
mozzles's Avatar
mozzles
Tire pressure
Should I air them all to the same pressure like the tires say (80psi I'm pretty sure) or what my door says, which is like 66 in the front and 80 in the back I believe (not looking at it right now)? Thanks,
Zac
Old Dec 12, 2012 | 11:51 AM
hairyboxnoogle's Avatar
hairyboxnoogle
Like 4 threads down is a thread talking about the EXACT same thing.
Old Dec 12, 2012 | 12:04 PM
sammie0126's Avatar
sammie0126
Zac
What's on your door sticker is what you should use.
Old Dec 12, 2012 | 04:46 PM
tecgod13's Avatar
tecgod13
x2
No, for proper tire wear the pressure depends on the loading. If your truck is fully loaded most of the time, the door tag is probably good, but if you're unloaded most of the time, air down for even tire wear.
Old Dec 12, 2012 | 05:00 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
65-70 all the way around if you are unloaded if you have load range E's. if you are running D's then max them out at 65psi.
scameron7
2009 - 2014 F150
17
Dec 2, 2012 06:45 AM
esebm
Escape & Escape Hybrid
Aug 16, 2010 08:43 AM
DEW34
2004 - 2008 F150
Oct 15, 2007 04:22 PM
therigwelder
Oct 17, 2006 08:41 PM
WKMOTZU
Mar 12, 2003 09:20 AM
