Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Tire pressure?
Old Aug 5, 2010 | 02:20 PM
esebm's Avatar
esebm
Tire pressure?
Hi,
I just got a set of tires (Goodyear Wrangler SR-A) installed. Although the door sticker says the tire pressure should be 30psi, the tire guy inflated to 40psi because that's what was written on the tire. Who should I believe, the door sticker or the tire guy?
Thanks,
Ed
Old Aug 5, 2010 | 02:30 PM
RRranch's Avatar
RRranch
The tire guy is an idiot who can't read and should be fired!! It says MAXIMUM pressure 40 on the sidewall if you look a little closer. Fill them to what your door sticker says.
Old Aug 5, 2010 | 06:22 PM
tcesni's Avatar
tcesni
I have had morons inflate tires to the max at both tire stores and at quick lubes. Idiots!! Just last week I thought that my Escape seemed to be wandering a bit and then I remembered that I had stopped at a quick lube as my dealer was booked for a week. 44 lbs. all the way around.
Old Aug 5, 2010 | 06:29 PM
wptski's Avatar
wptski
Gosh, don't say that in a Hybrid forum! I know one with a '09 FEH running 50psi.
Old Aug 6, 2010 | 09:50 AM
esebm's Avatar
esebm
Well, the tire shows 44 psi as the maximum.
Ed
Old Aug 6, 2010 | 10:27 PM
wptski's Avatar
wptski
That's the max pressure at max load though.
Old Aug 7, 2010 | 02:32 PM
Nitramjr's Avatar
Nitramjr
Gary does tend to push the limits, doesn't he?
I run mine a bit over the 35 recommended for the hybrids. The ride quality doesn't change at all even up to 40 psi. I keep mine around 39 or so. It is a noticeable difference in mileage though.
Old Aug 7, 2010 | 03:36 PM
wptski's Avatar
wptski
Yes, do you remove your right shoe also??
This may be vehicle dependent. I left a lube place in my '97 Ranger, hit some type of bump/hole and my rearend changed lanes on me. They overinflated my tires also.
Old Aug 7, 2010 | 04:10 PM
Nitramjr's Avatar
Nitramjr
No, I take them both off when it isn't winter time here but I do that in my truck too.
I have never had a problem with handling with my tires up around 40 and the roads around Boston are known for their poor surface quality. The hybrids have low rolling resistance tires (Conti Eco) but the vehicle suspension is the same (as far as I know) as the regular Escape.
I had a '94 Ranger 2wd that handled horribly with the bed empty regardless of tire pressure.
I've come out of tire places after having tires mounted and they always seem to be overinflated. Don't they have to inflate them to 40+ psi to get them to seat correctly?
Old Aug 7, 2010 | 09:44 PM
wptski's Avatar
wptski
My Ranger was the Splash model, so the box was fiberglass, even less weight! I inflate a few psi over doorsticker but that's about it for me.
Yeah, they do over inflate to pop on the bead but I think that it's wwwaayyy beyond 40psi. They just keep going till it pops. I think that I've heard of a few getting injured doing that too!
Old Aug 15, 2010 | 05:30 PM
tonyford's Avatar
tonyford
I just had a set if Dunlop Signatures put on my wife's 2008 Taurus. The recommend pressure is 32 psi all around. The next morning after the vehicle had been sitting all night I checked the pressure, wouldn't you know it there was about 40 psi in each tire. What is it with these tire dealer intallers? Why do they always over inflate new tires.
As far my Escape, I have a 2003 XLS, 15" tires. alwasy run 34 psi, handles great and tires wear good.
Old Aug 15, 2010 | 06:27 PM
tcesni's Avatar
tcesni
Apparently all tire installers can handle is reading the side wall of the tire. Looking at the manufacturer's decal is too much for them to handle. I remember once when I had new tires installed on my Mustang GT and they had 44 psi in them. Talk about a firm ride! Loosened some fillings.
Old Aug 15, 2010 | 07:03 PM
Nitramjr's Avatar
Nitramjr
I'm not in the habit of defending Ford dealerships or their service departments, but when I brought both of my Escapes in for alignments, the both came back with all tire set to exactly 35 psi.....which meant they let air out. I promptly put it back in.
And by the way, both of mine have 52,000 miles on the original Conti EcoPlus tires and all eight tires look like they could go another 30k.
Old Aug 15, 2010 | 07:18 PM
wptski's Avatar
wptski
The sidewall is marked with max psi but there's more! At a certain axle weight. If you figure your GVW-curb weight equal the max load that you "should" carry at the max sidewall psi. Max psi with no load equals a harsh ride.
Old Aug 16, 2010 | 08:43 AM
EBTDM's Avatar
EBTDM
Are you kidding me? Really?
Go with the tire pressure is on your door post. Then watch the wear and alignment issues. We all should be doing that anyway.
Wptski is completly right in more ways than one. You over inflate to the max tire rating (like when we were kids on bicycles) then the ride will be hash and probably bouncing the tire off the road surface. You under inflate and hit a pothole you have a nick in the rim and possibly a flat tire.
You have to watch YOUR tires, if you want to get a longest usage life from it.
jd1083
Jul 11, 2011 11:39 AM
rich gill
Nov 1, 2008 11:30 AM
bilter
Apr 19, 2005 07:37 PM
JJK05
1983 - 2012 Ranger & B-Series
17
Mar 3, 2005 09:01 PM
fishrising
Jun 19, 2004 10:39 PM
