Distributor install
Old Dec 8, 2012 | 06:40 PM
cjohn2000's Avatar
cjohn2000
Distributor install
Most of you probably saw a thread "Duraspark or Pertronix" So now that I finally have found a weekend that either isn't raining or im not busy I decided to try to gt my HEI dizzy into the truck. I can get the rotor to line up with the marks I made and drop in most of the way except the last 1/4 - 1/2" The only thing I can figure is that the oil pump drive shaft is not lined up, in terms of orientation, to the bottom of the dizzy. My only thought is to turn the oil pump driveshaft with a nutdriver. Anyone got any ideas? thanks corey
Old Dec 8, 2012 | 06:43 PM
cjohn2000's Avatar
cjohn2000
FYI its '69 250 camper special 390 ranger.
Old Dec 8, 2012 | 07:32 PM
BobbyFord's Avatar
BobbyFord
Hook a remote starter button up to the solenoid and bump it while turning back and forth on the distributor with a little downforce. Then bump the motor back around to TDC and check rotor to cap orientation.
Old Dec 10, 2012 | 03:50 PM
rustywheel68's Avatar
rustywheel68
remember- the distributor gear is curved. its not going to drop straight down. you need to put it down so that the rotor is pointing about about 1/2" counter-clockwise of where you need it to end up.
as it drops all the way down, the rotor will turn a bit, and hopefully end up right where you want it.
if it ends up slightly off...you're one tooth off. pull it out and try again.
Old Dec 10, 2012 | 06:56 PM
cjohn2000's Avatar
cjohn2000
I know its meshing ok with the other gear, as far as I can tell its just the oil pump driveshaft that is not orientated correctly. The only thing I can think of is to rotate the oilpump drive shaft. The old distributor had the same issue and would not drop straight in. I guess it would make sense that I could be a couple teeth off of where it was. The rotor of the new distributor is lining up pretty close (1/8")with my marks.
Old Dec 10, 2012 | 07:02 PM
BobbyFord's Avatar
BobbyFord
Bumping the motor over will turn the dist and line up the oil pump driveshaft.
Old Feb 11, 2013 | 02:45 AM
72Truckin's Avatar
72Truckin
I just purchased a CRT Performance Dizzy from eBay, so we'll how it goes for me.
One of the videos that I am using to help my reference with the install is the following, which may help with your install too, hopefully:
Old Feb 11, 2013 | 09:48 AM
willowbilly3's Avatar
willowbilly3
I've done it both ways and generally I like to used a nut driver to turn the oil pump a little, usually takes 2-3 tries.
Old Feb 11, 2013 | 08:44 PM
Redmanbob's Avatar
Redmanbob
[QUOTE=willowbilly3;12826237]I've done it both ways and generally I like to used a nut driver to turn the oil pump a little, usually takes 2-3 tries.[/QUOTE
easiest way as the timing stays set, just need about 1/16 a turn to get things to work out usually. Once they are close enough the dist will turn the pump on the way down.
Old Feb 11, 2013 | 11:52 PM
cjohn2000's Avatar
cjohn2000
The biggest obstacle I encountered was the o ring on the new distributor I ended up hose clamping and chilling the distributor and then setting it in place and using the distributor hold down and tightening and pushing down on the top of the distributor until it went "klunk" and dropped down into place. The cap on my distributor had no #1 marked on it so i referred to the old cap since the distributor were both positioned in the same orientation in regard to timing. Just make sure, if you need to in your application, to eliminate the pink resistor wire.
Culprit83
Jul 24, 2016 10:01 PM
cjben
Aug 4, 2008 08:24 AM
tcb89
Mar 19, 2006 02:04 AM
'73 250
Feb 16, 2005 11:28 PM
eandaauto
Aug 8, 2004 01:15 PM
