Rebuilding my oil cooler and I knocked off the front housing that bolts to the block before I remembered to mark were it located with the cooler tube. The back one had a paint mark that lines up with the locating tab for the rear so I was good there.
Will this thing be able to twist enough (if I have it close enough) once I get it rebuilt to line all the bolt holes up (and oil pass.) to mount it back on the motor?
