Locking Hubs Failure
Old Dec 8, 2012 | 11:38 AM
RyCoy's Avatar
RyCoy
My parents have a 2005 Excursion with the 3 position (lock, unlock, auto) locking hubs that use a vacume line for auto. The driver's side hub has **** the bed and the **** just spins freely. Dad and I took it apart and some of the internals are wore out. We were able to reassymble it in the "locked" position and put it back on so that it is locked in full time for right now. My question to the group is this- Can we put a conventional manual locking hub from a F-250 on the Excursion and just plug off the vacume line? The price of the excursion hubs is almost double what the 250 hubs are, and from what I rember of my '06 f250, the splines look identical.
Every 4wd they have owned prior to this had been manual locking hubs, so the whole family is used to getting out to lock the hubs if need be, so that is not a big issue, as long as it works.
Old Dec 8, 2012 | 12:04 PM
XbigXredX's Avatar
XbigXredX
As far as I know the warn and the milestone hubs are the recomendations around here for the manuals. And yes the f250's should fit as well as far as I know.
Old Dec 8, 2012 | 12:06 PM
RyCoy's Avatar
RyCoy
If warn made a replacement hub, I wouldn't be asking.
Old Dec 8, 2012 | 12:14 PM
XbigXredX's Avatar
XbigXredX
Well then you don't need to ask because warn most definitely makes one.
The Mile Marker part # is 449SS
Someone else will come along and be certain.
Old Dec 8, 2012 | 12:21 PM
RyCoy's Avatar
RyCoy
I've checked with four different retailers that sell Warn products and they have all told me the same thing, Warn does not list one. I've checked Warn's web sight, they don't list one. Warn stops at 2004. I need the hub for a 2005. Do you have a part number for Warn.
Old Dec 8, 2012 | 12:28 PM
XbigXredX's Avatar
XbigXredX
Correction- Warn #38826
See this thread-
https://www.ford-trucks.com/forums/8...r-an-05-x.html
Specifically post #5
Old Dec 8, 2012 | 12:33 PM
labman1014's Avatar
labman1014
The 05 Ex is exactly the same as the 04 except for the front clip. Ford changed the suspension for 05 up f250. So parts for an 04 ex will fit an 05.
Old Dec 8, 2012 | 12:49 PM
RyCoy's Avatar
RyCoy
Now that I feel like an arogant jackass, I stand corrected. I'm going to pull the hubs off of the excursion tonight to double check that they are the 30 spline hubs used up through 2004. XbigXredX, I appologize if I came off as disrespectful.
Old Dec 8, 2012 | 01:14 PM
XbigXredX's Avatar
XbigXredX
No worries, we're all here trying to help each other. Thanks for the apology you're a stand up guy. My apologies if I was curt as well. Hope you get the truck all fixed, let us know we like to see the end results.
JonDavis1984
Feb 1, 2014 12:29 PM
93F250
Feb 11, 2009 12:40 PM
Drumfish
Aug 12, 2007 10:31 AM
LeeroyDiesel
Sep 11, 2006 02:03 PM
